SDKV12 sdk_config.h "master" ?
Hello. I have a question and a request for Nordic developers.
It is really super-helpful that in SDKV12 you converted to having a master sdk_config.h that contains what seems to be 100% of all sdk config parameters. This is terrific.
What has been making conversion from SDK11 a bit more challenging for me, however, is the fact that I can't seem to find a "master" sdk_config.h that contains 100% of all parameters. It has been a trial and error process that involves scanning the sdk_config.h's contained within the various examples, which seem to have differing subsets of sdk_config.h.
Furthermore, in at least one case I was stumped by the fact that there were no sdk_config.h's at all, in any of the examples, that had a parameter that turned out to be necessary and should have been in there: APP_GPIOTE_ENABLED.
I don't know what other developers do, but what I would like to be able to do each time a new SDK is released is this:
  1. Go into a subfolder of /documentation that contains the "master" sdk_config.h for that release
  2. Diff it against the "master" sdk_config for the previous release.
  3. Manually upgrade my own sdk_config.h's based upon what I find.
I say this because given the number of parameters it can be tricky and error-prone to propagate an app's config parameters from one release to another. If the Nordic devs would maintain the sdk_config.h in a "readily diff-able" manner, it would really help 3rd party devs in sdk transitions.
Thanks for your consideration.
  • I agree with Krzysztof, pin assignment shouldn't be in sdk_config.h. For example TWI pins, pin numbers are part of nrf_drv_twi_config_t being passed into nrf_drv_twi_init. Different developer has different opinion for where the pin definition needs to be. I think there could be a "master/example" sdk_config.h, but not a "standard" one. Different applications will require different project structuring. Different developers also have their unique "habits" for organizing defines. And I do agree that I spend some time every time upgrading into a new SDK revision, and got caused many times because the code did pass compiler/linker. I understand that this is probably the most efficient way for Nordic to upgrade their SDK without considering too much about backwards compatibility. But thanks to this forum, luckily most of the traps have been reported here. Bookmark the devzone and move on :-)
