nRF51822 over the air bootloader - nRF Mcp freezes or reports GATT ERROR
Today, I tried out the Ble Bootloader from the Sdk examples. As a central client, I'd used the »nRF Loader App« an an iPhone and also »nRF Mcp« on an Android Tablet.
I tried it out with some different application binaries (all are attached to this post). The Blinky is slightly different agains the sck examples (a bit different blinking pattern). All application binaries My test target is a nRFgo: nRF6310 Rev 1.4 Motherboard with PCA10004 Rev 2.0.0 cpu module. For each test run I began with nRFgo Studio "Erase all", "Program SoftDevice" & "Program Bootloader" to have always a clean base.
The results are as followes.
Update via nRF Loader (iPhone), needs *.bin update files:- Blinky Debug -> Update ok, application works as expected
  • Blinky Release -> Update ok, application works as expected
  • Hrs Debug -> Update ok, application works as expected
  • Hrs Release -> Update ok, application works as expected
  • Hrs Debug2 -> Update ok, application works as expected
  • buildin ble_app_hrs -> Message "Finished upload!", but no Ble Peripheral visible on Mcp or LightBlue
  • buildin ble_app_rscs -> dito
Update via nRF Mcp (Android), needs *.hex update files:- Blinky Debug -> Starting DFU -> no progress bar, ends up in a screen with: "Status: GATT ERROR \n NOT BONDED"
  • Hrs Debug -> Starting DFU -> freezes at 20%
  • Hrs Release -> Starting DFU -> freezes at 36%
  • Hrs Debug2 -> Starting DFU -> freezes at 20% Look's like an issue with the "nRF Master Control Panel" Android app, isn't it?
nRF-Binaries.zip
  • Hi, is this problem is solved?
    In my case, I use a Samsung Galaxy S4 (SHV-E330S) with Android 4.4.2.
    The Master Control Panel's version is 3.1.0.
    The Toolbox's version is 1.14.1.
    Surprisingly, my other test device, Nexus 5 with Android 5.1.1, doesn't have the problems above.
    However, this Samsung device kept shows the same phenomena:
    the Dropbox comes up after I select a file from Toolbox - DFU or Master Control Panel.
    I erased the Toolbox app and the Master Control Panel and installed them 4 times but it kept happens.
    Is there any solutions?
    Added : After erasing the dropbox app and installing "File Manager" app,
    finally, I could select the .hex file and init file.
    But I have to use the dropbox app. Is there another way to solve it?
    -Regards
