PC-BLE-Driver with connectivity board doesn't connect as master
I have been using pc-ble-driver in Linux (downloaded and compiled from github here - github.com/.../3316c0c306257a825168751964f814cb95fc0d74) with our custom C++ application that is supposed to work in Central and Peripheral roles simultaneously.
For some reason, when I try to connect as Central, using sd_ble_gap_connect(adapter, p_peer_addr, p_scan_params, p_conn_params); I always get NRF_ERROR_INTERNAL. I do not have any problems with connecting as Peripheral. That is the following always returns 3.
 err_code = sd_ble_gap_connect(adapter, p_peer_addr, p_scan_params, p_conn_params);
Here is the BLE_enable code that is used in the intialization before any other API calls are made...
      params.common_enable_params.vs_uuid_count   = 1;
      params.gatts_enable_params.attr_tab_size = 0;
      params.gatts_enable_params.service_changed = 1;
      params.gap_enable_params.periph_conn_count = 1;
      params.gap_enable_params.central_conn_count = 1;
      params.gap_enable_params.central_sec_count = 1;
     err_code = sd_ble_enable(adapter, &params, NULL); // Tried both NULL and 0x20002418
I am kinda stuck here. Any pointers much appreciated.
