I use SDK 12 softdevice 130 2.0.1
The example project of HID is running on my nrf51822 board, it is pairs with iPhone but the windows 7 write that the HID driver is not install correctly.
Any idea?
Thanks.
Any idea?
Thanks.
Yes,after adding this report just osx,android,ios working. Windows not.
static uint8_t report_map_data[] = { 0x05, 0x01, // Usage Page (Generic Desktop) 0x09, 0x06, // Usage (Keyboard) 0xA1, 0x01, // Collection (Application) 0x85, 0x01, // Report Id (1) 0x05, 0x07, // Usage Page (Key Codes) 0x19, 0xe0, // Usage Minimum (224) 0x29, 0xe7, // Usage Maximum (231) 0x15, 0x00, // Logical Minimum (0) 0x25, 0x01, // Logical Maximum (1) 0x75, 0x01, // Report Size (1) 0x95, 0x08, // Report Count (8) 0x81, 0x02, // Input (Data, Variable, Absolute)
0x95, 0x01, // Report Count (1)
0x75, 0x08, // Report Size (8)
0x81, 0x01, // Input (Constant) reserved byte(1)
0x95, 0x05, // Report Count (5)
0x05, 0x08, // Usage Page (Page# for LEDs)
0x19, 0x01, // Usage Minimum (1)
0x29, 0x05, // Usage Maximum (5)
0x91, 0x02, // Output (Data, Variable, Absolute), Led report
0x75, 0x03, // Report Size (3)
0x91, 0x01, // Output (Data, Variable, Absolute), Led report padding
0x95, 0x06, // Report Count (6)
0x25, 0x65, // Logical Maximum (101)
0x05, 0x07, // Usage Page (Key codes)
0x19, 0x00, // Usage Minimum (0)
0x29, 0x65, // Usage Maximum (101)
0x81, 0x00, // Input (Data, Array) Key array(6 bytes)
0x09, 0x05, // Usage (Vendor Defined)
0x26, 0xFF, 0x00, // Logical Maximum (255)
0x75, 0x08, // Report Count (2)
0x95, 0x02, // Report Size (8 bit)
0xB1, 0x02, // Feature (Data, Variable, Absolute)
0xC0, // End Collection (Application)
0x05, 0x0C, // Usage Page (Consumer)
0x09, 0x01, // Usage (Consumer Control)
0x85, 0x02, // Report ID (2)
0x0A, 0xAE, 0x01, // Usage (AL Keyboard Layout)
0x81, 0x06, // Input (Data,Var,Rel,No Wrap,Linear,Preferred State,No Null Position)
@max: Sorry for late response. I am not sure what could be the issue here. But above you mentioned that it worked on Windows with S130 v2.0.0 but not on S130 v2.0.1 ? Could you provide 2 sniffer traces, one capture your device with S130 v2.0.0 and one with S130 v2.0.1 ?
I'm having the same problems. Works fine on Mac OS/Android - but Driver Error on windows 10. Is there some kind of error log that I could track this down with to see what the error was?
Just to add - in the Windows System log it says it concluded the driver install process with error code 0 - which sounds good to me...
