nRF51822 over the air bootloader with gcc
For my current project, I need to compile the »over the air bootloader« with gcc (because our buildserver runs on linux, developers using Mac … no Windows and no Keil so far).
But unfortunaly, the bootloader example from the sdk (5.1) examples won't compile with gcc. It's missing gcc makefile and even there are at least 2 Keil specific files in the project (arm_startup_nrf51.s and bootloader_util_arm.c).
Could you provide support to help me on this topic?
I'd also checked:- devzone.nordicsemi.com/index.php/nrf51822-bootloader-with-gcc
  • Rather I don't use makefile from sdk but I set eclipse project settings based on makefile from sdk. See this thread: https://devzone.nordicsemi.com/index.php/creating-a-new-project-under-eclipse-from-scratch
  • I can't find the attached archive you refer to at the beginning of your post.
    Are you using Ole's github bootloader_startup_nrf51.s or gcc_startup_nrf51.s in sdk ?
    -c
  • I'd performed some rework last night, especially regarding the bootloader's codesize. The new attachment is now here.
    Startup code: Within pure-gcc, I use Ole's template/startup_nrf51.s. For sdk gcc build, I use the gcc_startup_nrf51.s from the sdk templates directory.
  • Hi, thanks for sharing both your codes. I'm working on both OSX and Linux, and I've made some modifications (more or less like the ones made by Nikita) to make the bootloader code compile with gcc. I build the code with the standard gcc configuration (not hlnd/pure-gcc).
    The problem is that using 0x3C000 as BOOTLOADER_REGION_START, with FLASH (rx) : ORIGIN = 0x0003C000, LENGTH = 0x4000 ends with:
    _build/dfu_single_bank_ble_s110.out section `.text' will not fit in region `FLASH'
    ld: region `FLASH' overflowed by 10600 bytes
    My current Makefile is this:
    TARGET_CHIP := NRF51822_QFAA_CA
    BOARD := BOARD_NRF6310
    CFLAGS += -DBLE_STACK_SUPPORT_REQD -DBOOTLOADER_BANKED
    SDK_PATH = /opt/nrf51/nrf51_sdk_v5_2_0_39364/nrf51822/
    C_SOURCE_FILES = main.c
    C_SOURCE_FILES += bootloader_util_arm.c
    C_SOURCE_FILES += bootloader.c
    C_SOURCE_FILES += dfu_single_bank.c
    C_SOURCE_FILES += dfu_transport_ble.c
    C_SOURCE_FILES += $(SDK_PATH)Source/app_common/app_timer.c
    C_SOURCE_FILES += $(SDK_PATH)Source/app_common/app_scheduler.c
    C_SOURCE_FILES += $(SDK_PATH)Source/app_common/app_gpiote.c
    C_SOURCE_FILES += $(SDK_PATH)Source/app_common/crc16.c
    C_SOURCE_FILES += $(SDK_PATH)Source/sd_common/softdevice_handler.c
    C_SOURCE_FILES += $(SDK_PATH)Source/app_common/pstorage.c
    C_SOURCE_FILES += $(SDK_PATH)Source/app_common/hci_mem_pool.c
    C_SOURCE_FILES += $(SDK_PATH)Source/ble/ble_conn_params.c
    C_SOURCE_FILES += $(SDK_PATH)Source/ble/ble_advdata.c
    C_SOURCE_FILES += $(SDK_PATH)Source/ble/ble_services/ble_srv_common.c
    C_SOURCE_FILES += $(SDK_PATH)Source/ble/ble_services/ble_dfu.c
    INCLUDEPATHS += -I"../include"
    INCLUDEPATHS += -I"../include/ble_transport"
    INCLUDEPATHS += -I"$(SDK_PATH)Include/ble"
    INCLUDEPATHS += -I"$(SDK_PATH)Include/s110"
    INCLUDEPATHS += -I"$(SDK_PATH)Include/app_common"
    INCLUDEPATHS += -I"$(SDK_PATH)Include/ble/ble_services"
    INCLUDEPATHS += -I"$(SDK_PATH)Include/sd_common"
    OUTPUT_FILENAME := dfu_single_bank_ble_s110
    # Use custom linker script
    LINKER_SCRIPT := gcc_nrf51_s110_xxaa_bl.ld
    CFLAGS += -Os -flto -ffunction-sections -fdata-sections -fno-builtin
    LDFLAGS += --specs=nano.specs -lc -lnosys -Wl,--gc-sections
    include $(SDK_PATH)Source/templates/gcc/Makefile.common
    Have you experienced these problems with executable size when dealing with bootloader code at 0x3C000? Are there any compiler settings to set to reduce code size to fit at 0x3C000?
    Thanks for any help.
    Samuele.
