[SDK12][PCA10040]ble_app_buttonless_dfu not resetting to bootloader
I have modified my files as mentioned here. When I upload the package, the template device show and I am able to connect. But when I subscribe to the notification and write 0x01, the device doesn't reboot.
In bootloader log it asks to change the ram start address:
:INFO:Inside main
:INFO:In nrf_bootloader_init
:INFO:In real nrf_dfu_init
:INFO:running nrf_dfu_settings_init
:INFO:!!!!!!!!!!!!!!! Resetting bootloader settings !!!!!!!!!!!
:INFO:Erasing old settings at: 0x0007f000
:INFO:Erasing: 0x0007f000, num: 1
:INFO:Writing 0x00000057 words
:INFO:Writing settings...
:INFO:Enter nrf_dfu_continue
:INFO:Single: Invalid bank
:INFO:Enter nrf_dfu_app_is_valid
:INFO:Return false in valid app check
:INFO:In nrf_dfu_transports_init
:INFO:num transports: 1
:INFO:vector table: 0x00075000
SDH:INFO:sd_ble_enable: RAM START at 0x20002c00
SDH:WARNING:sd_ble_enable: app_ram_base should be adjusted to 0x20002798
SDH:WARNING:ram size should be adjusted to 0xd868
:INFO:After nrf_dfu_transports_init
:INFO:------- nrf_dfu_flash_init-------
:INFO:Waiting for events
Here is the log without changing the base address:
SDH:INFO:sd_ble_enable: RAM START at 0x20002128
:INFO:Erasing old settings at: 0x200021ac
:INFO:Erasing: 0x200021ac, num: 1
:INFO:Erase failed: 6
:INFO:Failed to erase bootloader settings
APP:INFO:Indication for BLE_DFU is enabled
APP:INFO:Indication for BLE_DFU is disabled
APP:INFO:Device is entering bootloader mode!
Here is the log after changing the address:
I have tried with both debug bootloader and normal one, the problem remains the same. I am using GCC on Linux. Please help.
Thanks in advance :)
[EDIT]
When I power on the board with BUTTON 4 pressed, the device starts in bootloader mode. Here is the log:
:INFO:Inside main
:INFO:Valid App
:INFO:Application sent bootloader request
Also LED3 and LED1 are turned on in this state, not LED4. If I connect LED2 will turn on and LED1 will turn off. I guess this is the desired result right?
[EDIT]
This is the process that I'm following:
  • Erase the flash
  • Program Softdevice from buttonless_dfu Makefile using make flash_softdevice
  • Program bootloader_secure from pca10040_debug Makefile using make flash
  • Create package in buttonless_dfu directory using
    nrfutil pkg generate --debug-mode --key-file priv.pem --application _build/nrf52832_xxaa.hex pkg.zip
  • Transfer the zip to phone and upload using nrfConnect
  • Successfully upload the file
  • Device resets.
  • Connect to the device and enable notification on the unknown characteristic
  • Write 0x01 on the characteristic
  • The received response is 20-01-01, and the logs are as mentioned in the question.
I hope I am not doing anything wrong here.
  • @bjorn-spockeli yes, I'm looking for the same solution discovered by Keton (original linker file was lacking .bootloaderSettings section) but for the nRF51 since the location of the bootloader settings will likely be different.
    EDIT @bjorn-spockeli I realized I could just look at the linker script of the bootloader I am using to find the corresponding locations in memory: /** Location of bootloader setting in at the last flash page. */ BOOTLOADER_SETTINGS (rw) : ORIGIN = 0x0003FC00, LENGTH = 0x0400
    I also found that the BLE_UUID_DFU_SERVICE is missing from the advertised services list in main.c. Until I added this I could not write to the service to place the board in dfu mode.
