drv_uart vs uart_app functions
Are the functions implemented in drv_uart and uart_app even related to each other? I noticed that uart_app implements only some simple functions. Can someone please explain to me the differences between these implementations? Can I freely call the functions from either of them? Are they any different from the blocking point of view?
-vala
  • I am well aware of the example. I ended up doing this in my init function
    err_code = app_uart_init(&comm_params,
                           NULL,
                           UART0_IRQHandler_New,
                           APP_IRQ_PRIORITY_LOW);
    where I used the modified name of the UART0_IRQHandler so building would succeed. What I don't know is if it works. I won't know that until I flash the production device versus the DK.
    I know the UART0_IRQHandler works in the old code (it IS a poll as I get signaled then I have to do a simple_uart_get(&data) to get the data). The down side is that flash writes DONT work in the old version but they DO work in the new version.
  • Ok, I see what you are doing now. The handler you pass to app_uart_init is not an interrupt handler, it is an event handler, where you should handle events passed from the library to the application. An example event handler is shown in the UART example and on this page. The name of this handler can be whatever you want, as the library will call the function you pass to the init function.
    Note that if you want to send more than one byte at a time, you need to use the app_uart_fifo implementation. Initialization should also be done through the macros APP_UART_INIT/APP_UART_FIFO_INIT to be safe.
  • Jorgen, that init function was taken from the UART example (that you referenced) earlier, as it was the closest mapping I could get to the original. In the UART example the event handler was for errors. But you are correct, it is an event handler as it was in the original 'simple_uart_* model.
    I am bound to the original as the sensor MCU is pre-specified and out of my hands - I can't change it. As it is it appears to send only one byte at a time. What I am hoping is that my code using the latest version of SoftDevice that can be supported on the nRF51822 (which works on the DK) will work when I flash the nrf51822 sitting on the YJ-14001-NRF51822 board of this production device. The only difference is that on the DK I use a button push to simulate what the sensor will send me via UART.
    I have made it simpler for myself by using just sd_* calls for all BTLE functionality (including bonding) and flash writes. Everything works using s110 on the production device EXCEPT for the sd_flash_write(). Using s130 in the DK the flash write also works.
    The other fear I have is that the old code uses a p10001 board and the DK uses a p10028. I am hoping the p10028 code will be compatible with the YJ-14001-NRF51822, at least on the level we are using it (the UART PINS appear to be the same....).
  • You can check the compatibility matrices for relations between Development HW and chip revision, chip revision and SDKs and SoftDevices support, and you can compare the chip on your production board towards nRF51822 IC revisions and variants.
  • Jorgen,
    I have looked at all of these before, but I have not found any information about the meaning of p10001, p10028, etc. that appear in the code base. For example, in the downloaded 12.3.0 SDK there are three directories for each example, pca10028, pca10040, and pca10056. In the original project there was a pca10001. These are all associated with 'boards'. Where can I find info about that? How does p10001 relate to p10028? There are different 'h' files for each of these.
