Triggering event handler upon CCCD for notifications change
In the ble_nus service (SDK11.0.0 S132 nRF52), what is the simplest way to modify on_write() to send inform the main application the CCCD for notifications has changed:
static void on_write(ble_nus_t * p_nus, ble_evt_t * p_ble_evt){
ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
if (
    (p_evt_write->handle == p_nus->rx_handles.cccd_handle)
    (p_evt_write->len == 2)
    if (ble_srv_is_notification_enabled(p_evt_write->data))
        p_nus->is_notification_enabled = true;
        p_nus->is_notification_enabled = false;
else if (
         (p_evt_write->handle == p_nus->tx_handles.value_handle)
         (p_nus->data_handler != NULL)
    p_nus->data_handler(p_nus, p_evt_write->data, p_evt_write->len);
    // Do Nothing. This event is not relevant for this service.
Currently just the is_notification_enabled field is set, but the event handler is not triggered in the application level, so the application will not be informed or know that some data in p_nus has been modified.
  • I think I confused you by saying "main application". What I mean is that I want the event handler p_nus->data_handler() to be called with some information stating that the CCCD has changed. What is the simplest way to do this?
  • in that case just add one more variable in ble_nus_t
    bool cccd_changed;
    and on write
    if (
        p_nus->cccd_changed = true;
    else if (
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
      if(p_nus->cccd_changed)
         p_nus->cccd_changed = false;
         // do your processing here
