stdint.h: No such file or directory
I'm trying to compile an example of nRF52_SDK_1 but I get this error:
make
Makefile:150: Cannot find include folder:  ../../../config/receiver_pca10040
mkdir _build
Compiling file: nrf_log_backend_serial.c
In file included from ../../../../../../../components/libraries/util/sdk_errors.h:45:0,
                 from ../../../../../../../components/libraries/log/nrf_log_ctrl.h:26,
                 from ../../../../../../../components/libraries/log/nrf_log_backend.h:27,
                 from ../../../../../../../components/libraries/log/src/nrf_log_backend_serial.c:14:
/usr/lib/gcc/arm-none-eabi/6.1.0/include/stdint.h:9:26: fatal error: stdint.h: No such file or directory
 # include_next <stdint.h>
compilation terminated.
../../../../../../../components/toolchain/gcc/Makefile.common:108: fallo en las instrucciones para el objetivo '_build/nrf52832_xxaa_nrf_log_backend_serial.c.o'
make: *** [_build/nrf52832_xxaa_nrf_log_backend_serial.c.o] Error 1
How I can fix it?
GCC -ver
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/6.2.1/lto-wrapper
Objetivo: x86_64-redhat-linux
Configurado con: ../configure --enable-bootstrap --enable-languages=c,c++,objc,obj-c++,fortran,ada,go,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --disable-libgcj --with-isl --enable-libmpx --enable-gnu-indirect-function --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Modelo de hilos: posix
gcc versión 6.2.1 20160916 (Red Hat 6.2.1-2) (GCC)
Makefile.posix
GNU_INSTALL_ROOT := /usr
GNU_VERSION := 6.2.1
GNU_PREFIX := arm-none-eabi
Makefile.common
# Copyright (c) 2016 Nordic Semiconductor. All Rights Reserved.
# The information contained herein is property of Nordic Semiconductor ASA.
# Terms and conditions of usage are described in detail in NORDIC
# SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
# Licensees are granted free, non-transferable use of the information. NO
# WARRANTY of ANY KIND is provided. This heading must NOT be removed from
# the file.
PLATFORM_SUFFIX := $(if $(filter Windows%,$(OS)),windows,posix)
TOOLCHAIN_CONFIG_FILE := $(TEMPLATE_PATH)/Makefile.$(PLATFORM_SUFFIX)
include $(TOOLCHAIN_CONFIG_FILE)
# Toolchain commands
CC      := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-gcc"
CXX     := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-c++"
AS      := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-as"
AR      := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-ar" -r
LD      := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-ld"
NM      := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-nm"
OBJDUMP := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-objdump"
OBJCOPY := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-objcopy"
SIZE    := "$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-size"
$(if $(shell $(CC) --version),,$(info Cannot find: $(CC).) \
  $(info Please set values in: "$(abspath $(TOOLCHAIN_CONFIG_FILE))") \
  $(info according to the actual configuration of your system.) \
  $(error Cannot continue))
# Use ccache on linux if available
CCACHE := $(if $(filter Windows%,$(OS)),, \
               $(if $(wildcard /usr/bin/ccache),ccache))
CC     := $(CCACHE) $(CC)
MK := mkdir
RM := rm -rf
# echo suspend
ifeq ($(VERBOSE),1)
  NO_ECHO :=
  NO_ECHO := @
endif
# $1 type of item
# $2 path to check
define ensure_exists
$(if $(wildcard $(2)),, $(warning Cannot find $(1): $(2)))
endef
# $1 object file
# $2 source file
define bind_obj_with_src
$(eval $(1) := $(2))
endef
# $1 target name
# $2 list of source files
define get_object_files
$(foreach src_file, $(2), \
  $(call ensure_exists,source file, $(src_file)) \
  $(eval obj_file := \
    $(OUTPUT_DIRECTORY)/$(strip $(1))_$(notdir $(src_file)).o) \
  $(eval $(strip $(1))_dependencies += $(obj_file:.o=.d)) \
  $(call bind_obj_with_src, $(obj_file), $(src_file)) \
  $(eval $(obj_file): Makefile) \
  $(obj_file))
endef
# $1 target name
# $2 link target name
define prepare_build
$(eval $(2): \
  $(call get_object_files, $(1), $(SRC_FILES) $(SRC_FILES_$(strip $(1))))) \
$(eval INC_PATHS := \
  $(foreach folder, $(INC_FOLDERS) $(INC_FOLDERS_$(strip $(1))), \
    $(call ensure_exists,include folder, $(folder)) \
    -I"$(folder)"))
endef
# $1 target name
define define_target
$(eval OUTPUT_FILE := $(OUTPUT_DIRECTORY)/$(strip $(1))) \
$(eval $(1): $(OUTPUT_FILE).out $(OUTPUT_FILE).hex $(OUTPUT_FILE).bin) \
$(call prepare_build, $(1), $(OUTPUT_FILE).out)
endef
# $1 target name
# $2 library file name
define define_library
$(eval $(1) := $(2)) \
$(call prepare_build, $(1), $(1))
endef
.PHONY: $(TARGETS) default all clean help flash
all: $(TARGETS)
clean:
	$(RM) $(OUTPUT_DIRECTORY)
# Create build directories
$(OUTPUT_DIRECTORY):
	$(MK) $@
# Create objects from C source files
$(OUTPUT_DIRECTORY)/%.c.o: | $(OUTPUT_DIRECTORY)
	@echo Compiling file: $(notdir $($@))
	$(NO_ECHO)$(CC) -std=c99 $(CFLAGS) $(INC_PATHS) -c -o $@ "$($@)"
# Create objects from C++ source files
$(OUTPUT_DIRECTORY)/%.cpp.o: | $(OUTPUT_DIRECTORY)
	$(NO_ECHO)$(CXX) $(CFLAGS) $(CXXFLAGS) $(INC_PATHS) -c -o $@ "$($@)"
# Create objects from assembly files
$(OUTPUT_DIRECTORY)/%.S.o \
$(OUTPUT_DIRECTORY)/%.s.o: | $(OUTPUT_DIRECTORY)
	@echo Assembling file: $(notdir $($@))
	$(NO_ECHO)$(CC) -std=c99 $(ASMFLAGS) $(INC_PATHS) -c -o $@ "$($@)"
# Link object files
%.out:
	@echo Linking target: $@
	$(NO_ECHO)$(CC) -Wl,-Map=$(@:.out=.map) $(LDFLAGS) $^ $(LIB_FILES) -lm -o $@
	-@echo ''
	$(NO_ECHO)$(SIZE) $@
	-@echo ''
# Create binary .bin file from the .out file
%.bin: %.out
	@echo Preparing: $@
	$(NO_ECHO)$(OBJCOPY) -O binary $< $@
# Create binary .hex file from the .out file
%.hex: %.out
	@echo Preparing: $@
	$(NO_ECHO)$(OBJCOPY) -O ihex $< $@
Best regards
