SD132 NRF52 gcc debugging
Hi
I'm trying to port my firmware to the NRF52 DK, but I'm having trouble getting it to work. Could you give me a hint based on the stack trace below, what the problem might be?
Thread #1 <main> (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
	0x20001248
	<signal handler called>() at 0xfffffff9
	0xf5bbf576
	0x1000000
I'm using
  • SEGGER J-Link GDB Server V5.12g
  • gcc 5.4 q2
  • Eclipse Mars
Everything works fine for the NRF51 DK... This is driving me crazy..
Thanks for your hints in advance!
  • Just thinking out loud... the lower nine bits of XPSR shows it is a hard fault. The PC is in RAM, which is strange. The SP is a very small number, which is strange, the stack is high in RAM and grows down? The LR is odd, aren't instructions word aligned? How did you choose your .ld file, since the example/ble_app_template/s132/....ld is different? I could be wrong on any of this. Are you able to step through assembly code and do you have a reading knowledge of assembler (that is how I might tackle this?)
  • Agree with what @butch is saying. I can't make much sense of register values other than that there is some memory corruption. I suspect this can be related to either the startup files or that the "common" linker script is for the 51.
    Your .ld settings seems correct, worst case with these settings is that you get a "no mem" assertion when enabling the stack if the RAM base is too low. It should not end up in a hardfault.
    I would suggest to use try with the example/ble_app_template/s132/ example, and change the makefile so that it includes your source files, and see if it makes any difference. This should at least ensure that the startup and linker configurations are correct.
  • Thanks for your help!
    The hint with checking the Makefile and ld-file in deep was the clue... When moving my source files to the nrf52 makefile I copied the system_nrf51.c files... This lead to the odd behaviour...
    Such a dumb mistake. Thanks for your time in pinning this down!
