How to store Float array in nRF51 using FDS
hi NORDIC,
is it possible to store float array in fds. i am able to store intrger values but unable to store float values. i am using example in this link :- github.com/.../nRF52-fds-example
i am writing float m_deadbeef[20][3]; //////(LIKE this i need to store 5 arrays and i should retrieve it back) in to flash.
i dont know it is writing or not but writing is successful.
but while reading back the data i am getting empty spaces.
here is how i am reading back data from FDS
float *data;
uint32_t err_code;
    NRF_LOG_PRINTF("Start searching... \r\n");
// Loop until all records with the given key and file ID have been found.
while (fds_record_find(FILE_ID, REC_KEY, &record_desc, &ftok) == FDS_SUCCESS)
err_code = fds_record_open(&record_desc, &flash_record);
if ( err_code != FDS_SUCCESS)
return err_code;
NRF_LOG_PRINTF("Found Record ID = %d\r\n",record_desc.record_id);
NRF_LOG_PRINTF("Data = ");
 data = (float *) flash_record.p_data;
for (uint8_t i=0;i<flash_record.p_header->tl.length_words;i++)
NRF_LOG_PRINTF("%f ",data[i]);
NRF_LOG_PRINTF("\r\n");
i am getting emty data. please help me how to store float array in FDS.
> [EDIT]:
here is my write function...
static ret_code_t fds_test_write()
		#define FILE_ID     0x1111
		#define REC_KEY     0x2223
			fds_record_t        record;
			fds_record_desc_t   record_desc;
			fds_record_chunk_t  record_chunk;
			// Set up data.
				record_chunk.p_data         = m_deadbeef;
	record_chunk.length_words = sizeof(m_deadbeef)/sizeof(m_deadbeef[0][0]);
		// Set up record.
		record.file_id              = FILE_ID;
		record.key              	= REC_KEY;
		record.data.p_chunks       = &record_chunk;
		record.data.num_chunks   = 1;
		ret_code_t ret = fds_record_write(&record_desc, &record);
		if (ret != FDS_SUCCESS)
				return ret;
		 NRF_LOG_PRINTF("Writing Record ID = %d \r\n",record_desc.record_id);
		return NRF_SUCCESS;
