How to know location using LNS(location and Navigation Service) sdk example? speed and location are combined and encrypted
we are using nRF52-dk SDK examples
  • in code all values(battery,latitude and longitude,speed, navigation, and positional quality) is initialized. this values are transmitted. battery value is incremented or decremented 1 and speed is increased 1.2m every time
  • You can decode using Chapter 3.2 in the LNS spec, and this.
    When you enable the notifications you will receive the initial values for the characteristic (examine initial_lns_location_speed in the code).
    In nRF Connect you will receive:
    Attribute value changed, handle: 15, value (0x): 07-02-0C-00-34-09-00-2C-76-DA-F9-22-1D-D6-23
    The first 16 bits are the flag field. The first 6 bits tells you what fields that are present.
    0x07 = 0b00000111 -> Instantanours Speed, Total Distance, Location present
    0x02 = 0b00000010 -> Speed and Distance format is 3D
    The next 16 bits is the instantaneous speed (0x000C)
    The next 24 bits is the total distance (0x000934)
    The next 32 bits is the location - latitude (0xF9DA762C)
    The next 32 bits is the location - longitude (0x23D61D22)
