RTC with DS1307
For my application I use a RTC. For now without SD and based on SDK 11.0. Later I will implement it in an application with BLE. My device is a Raytac module with a nRF52832 on it. The module is connected with the RTC DS1307.
I think that I had success with write to the RTC. Because I get an ACK(NRF_DRV_TWI_EVT_DONE) back after the sequences. But I wont get anything when I try to read the registers of the RTC.
I assume that when I get a NRF_DRV_TWI_EVT_DONE this means, that the TX was successful and this is an ACK?
Does anyone have experience with the DS1307? What should I do, to get the data from the RTC?
And how many bytes do I have to expect to recieve?
Here my code:
#define SCL_PIN 15
#define SDA_PIN 14
#define SLAVE_ADRESSE_W				0x68
#define SLAVE_ADRESSE_R				0x69
#define SEKUNDEN_ADRESSE			0x00
#define MINUTEN_ADRESSE				0x01
#define STUNDEN_ADRESSE				0x02
#define TAG_ADRESSE					0x03
#define DATUM_ADRESSE				0x04
#define MONAT_ADRESSE				0x05
#define JAHR_ADRESSE				0x06
#define WERT_ADRESSE				0x05
uint8_t data[3];							//Array für Daten(3Bytes)
void DS1307_set_mode(void)
  ret_code_t err_code;
  uint8_t reg[2] = {SEKUNDEN_ADRESSE, WERT_ADRESSE};
  err_code = nrf_drv_twi_tx(&m_twi_driver, SLAVE_ADRESSE_W, reg, sizeof(reg), false);
  while(m_set_mode_done == false);
void read_data()
  uint8_t higher_byte;						//Variabel für höcherwertiges Byte aufsetzen
  uint8_t lower_byte;							//Variabel für niederwertiges Byte aufsetzen
  higher_byte 	= data[0];
  lower_byte	= data[1];
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch(p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
        if ((p_event->type == NRF_DRV_TWI_EVT_DONE) && (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX))
          nrf_drv_twi_rx(&m_twi_driver, SLAVE_ADRESSE_R, (uint8_t*)data, sizeof(data));
          read_data();
        if ((p_event->type == NRF_DRV_TWI_EVT_DONE) && (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX))
          read_data();
void twi_init (void)
    const nrf_drv_twi_config_t twi_mma_7660_config = {
   .scl                = SCL_PIN,
   .sda                = SDA_PIN,
   .frequency          = NRF_TWI_FREQ_100K,
   .interrupt_priority = APP_IRQ_PRIORITY_HIGH
    err_code = nrf_drv_twi_init(&m_twi_driver, &twi_mma_7660_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi_driver);
    twi_init();
    DS1307_set_mode();
     while(true)
From the Datasheet:
Depending upon the state of the R/W bit, two types of data transfer are possible:
  1. Data transfer from a master transmitter to a slave receiver. The first byte transmitted by the master is the slave address. Next follows a number of data bytes. The slave returns an acknowledge bit after each received byte. Data is transferred with the most significant bit (MSB) first.
  2. Data transfer from a slave transmitter to a master receiver. The first byte (the slave address) is transmitted by the master. The slave then returns an acknowledge bit. This is followed by the slave transmitting a number of data bytes. The master returns an acknowledge bit after all received bytes other than the last byte. At the end of the last received byte, a “not acknowledge” is returned.
The master device generates all the serial clock pulses and the START and STOP conditions. A transfer is ended with a STOP condition or with a repeated START condition. Since a repeated START condition is also the beginning of the next serial transfer, the bus will not be released. Data is transferred with the most significant bit (MSB) first.
image description
image description
  • This works in blocking mode. The read function gives zero once in a while, maybe because I am not checking the availability of twi.
    void twiWriteData(uint8_t regVal, uint8_t dataVal) { uint8_t reg[2] = {0,0};
    if (regVal == 100)
    	reg[0] = 0;
    	err_code = nrf_drv_twi_tx(&m_twi_driver, DS1307_ADDR, reg, 1, 0);
    reg[0] = regVal;
    reg[1] = dataVal;
    err_code = nrf_drv_twi_tx(&m_twi_driver, DS1307_ADDR, reg, 2, 0); }
    uint8_t twiReadData(uint8_t regVal) { uint8_t myVal = 0; err_code = nrf_drv_twi_tx(&m_twi_driver, DS1307_ADDR, &regVal, 1, 1);
    if (NRF_SUCCESS == err_code)
    	err_code = nrf_drv_twi_rx(&m_twi_driver, DS1307_ADDR, &myVal, 1);
    //twiWriteData(100,0);		// generate Stop condition
    return myVal;
    You need to write 0 to register 0 to kickstart the IC.
  • I have the same problem. Once I add a ds1307RTC.h library into my code then I can read the time on the serial port but ble stops advertising and is not visible by device. Once I comment that library then obviously cannot get the time but ble is discoverable.. Any solutions?
