BLE DFU update via Android hangs
Using SDK12.1 with nrf52. Have SD and bootloader on the device and trying to load application via BLE DFU. It randomly gets stuck. (see attached screenshot)
And if I do it via nRF Connect App i get "[DFU] Invalid response received (response: 0x600408, expected: 0x6004..) ". Below is the full log:
14:37:24.367	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V
14:37:24.457	Connecting to DB:CB:A0:27:8C:60... D
14:37:24.466	gatt = device.connectGatt(autoConnect = false) D
14:37:24.585	[Server callback] Connection state changed with status: 0 and new state: CONNECTED (2) D
14:37:24.683	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I
14:37:24.693	[Server] Device with address DB:CB:A0:27:8C:60 connected I
14:37:24.711	Connected to DB:CB:A0:27:8C:60 D
14:37:24.792	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED D 14:37:24.800	wait(600ms) V
14:37:25.424	Discovering services... D
14:37:25.511	gatt.discoverServices() D
14:37:25.526	[Callback] Services discovered with status: 0 I
14:37:25.552	Services discovered V	14:37:25.662	Generic Access (0x1800) - Device Name [R W] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) - Central Address Resolution [R] (0x2AA6) Generic Attribute (0x1801) Secure DFU Service (0xFE59) - DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50) - DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)    Client Characteristic Configuration (0x2902) V
14:37:47.461	Disconnecting... V
14:37:47.550	[Server] Cancelling server connection... D
14:37:47.559 server.cancelConnection(device) D
14:37:47.584	gatt.disconnect() D
14:37:47.646	[Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0) D
14:37:47.669	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0) I
14:37:47.694	[Server] Device disconnected I
14:37:47.715	Disconnected D
14:37:47.739	gatt.refresh() (hidden) D
14:37:47.754	gatt.close() D
14:37:47.845	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V	14:37:47.880	[DFU] DFU service started V	14:37:47.893	[DFU] Opening file... I
14:37:47.902	[DFU] Image file opened (28180 bytes in total) D
14:37:47.911	[DFU] wait(1000) D
14:37:48.904	[DFU] wait(1000) V
14:37:49.899	[DFU] Connecting to DFU target... D
14:37:49.913	[DFU] gatt = device.connectGatt(autoConnect = false) D
14:37:50.098	[Server callback] Connection state changed with status: 0 and new state: CONNECTED (2) I
14:37:50.119	[DFU] Connected to DB:CB:A0:27:8C:60 I
14:37:50.129	[Server] Device with address DB:CB:A0:27:8C:60 connected V
14:37:50.136	[DFU] Discovering services... D
14:37:50.146	[DFU] gatt.discoverServices() D
14:37:50.156	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED I	14:37:50.747	[DFU] Services discovered D
14:37:50.781	[DFU] wait(1000) V
14:37:51.761	[DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50 D	14:37:51.776	[DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true) D
14:37:51.786	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I
14:37:51.796	[DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00 V
14:37:51.806	[DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50 A 14:37:51.816	[DFU] Notifications enabled D	14:37:51.826	[DFU] wait(1000) V	14:37:52.806	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50 D	14:37:52.818	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50) I	14:37:52.827	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-01-00-00-90-00-00-00-51-CD-B6-A6 I
14:37:52.837	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-01-00-00-90-00-00-00-51-CD-B6-A6 A
14:37:52.845	[DFU] Command object info received (Max size = 256, Offset = 144, CRC = A6B6CD51) A
14:37:52.854	[DFU] Received CRC match Init packet V
14:37:52.863	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50 D
14:37:52.872	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50) I
14:37:52.882	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01 I
14:37:52.891	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01 A
14:37:52.901	[DFU] Command object executed V
14:37:52.910	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50 D	14:37:52.920	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50) I 14:37:52.931	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01 I
14:37:52.943	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01 A
14:37:52.954	[DFU] Packet Receipt Notif Req (Op Code = 2) sent (Value = 10) D
14:37:52.969	[Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0) V
14:37:52.992	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50 I	14:37:53.002	[Server] Device disconnected D
14:37:53.010	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50) I
14:37:53.019	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-10-00-00-00-10-00-00-66-43-46-21 I
14:37:53.028	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-10-00-00-00-10-00-00-66-43-46-21 A
14:37:53.037	[DFU] Data object info received (Max size = 4096, Offset = 4096, CRC = 21464366) A
14:37:53.046	[DFU] 4096 bytes of data sent before, CRC match V
14:37:53.055	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50 D
14:37:53.063	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50) I
14:37:53.072	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-08 I
14:37:53.081	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-08 E
14:37:53.090	[DFU] Invalid response received (response: 0x600408, expected: 0x6004..) V
14:37:53.100	[DFU] Disconnecting... D	14:37:53.110	[DFU] gatt.disconnect() I
14:37:53.119	[DFU] Disconnected D	14:37:53.129	[DFU] gatt.refresh() (hidden) D
14:37:53.139	[DFU] gatt.close() D	14:37:53.148	[DFU] wait(600) D
Any idea what could be wrong? Thanks!!
Update package
Bootloader secure
Screenshot DFU App Android
  • Maybe your android version does not have something BLE related... i am using android 6.0.1.
    If you have spare nRF52-DK, you could try DFU using nrfutil, I am using it with success right now.
  • I have Android 6.0, so not that much older... unfortunately dont have the DK from nrf52, only have old 51 DK.
  • I think it should also work with nrfutil. note that you also need newest version of nrfutil (installed ex. via pip)
  • have the latest nrfutils installed, but no luck:
    nrfutil dfu ble -pkg c:\Keil_v5\hello.zip
    No target selected. Default device name: DfuTarg is used.
    Please select connectivity serial port:
            0 : COM4 - 480110649
    Enter your choice: : 0
      [------------------------------------]    0%
      File "C:\Python27\Scripts\nrfutil-script.py", line 9, in <module>
        load_entry_point('nrfutil==1.5.0', 'console_scripts', 'nrfutil')()
      File "c:\Python27\lib\site-packages\click-6.6-py2.7.egg\click\core.py", line 716, in __call__
        return self.main(*args, **kwargs)
      File "c:\Python27\lib\site-packages\click-6.6-py2.7.egg\click\core.py", line 696, in main
        rv = self.invoke(ctx)
      File "c:\Python27\lib\site-packages\click-6.6-py2.7.egg\click\core.py", line 1060, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "c:\Python27\lib\site-packages\click-6.6-py2.7.egg\click\core.py", line 889, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "c:\Python27\lib\site-packages\click-6.6-py2.7.egg\click\core.py", line 534, in invoke
        return callback(*args, **kwargs)
      File "c:\Python27\lib\site-packages\nrfutil-1.5.0-py2.7.egg\nordicsemi\__main__.py", line 604, in ble
        dfu.dfu_send_images()
      File "c:\Python27\lib\site-packages\nrfutil-1.5.0-py2.7.egg\nordicsemi\dfu\dfu.py", line 117, in dfu_send_images
        self._dfu_send_image(self.manifest.application)
      File "c:\Python27\lib\site-packages\nrfutil-1.5.0-py2.7.egg\nordicsemi\dfu\dfu.py", line 82, in _dfu_send_image
        self.dfu_transport.open()
      File "c:\Python27\lib\site-packages\nrfutil-1.5.0-py2.7.egg\nordicsemi\dfu\dfu_transport_ble.py", line 176, in open
        self.dfu_adapter.open()
      File "c:\Python27\lib\site-packages\nrfutil-1.5.0-py2.7.egg\nordicsemi\dfu\dfu_transport_ble.py", line 83, in open
        self.adapter.driver.open()
      File "c:\Python27\lib\site-packages\wrapt\wrappers.py", line 561, in __call__
        args, kwargs)
      File "c:\Python27\lib\site-packages\pc_ble_driver_py-0.6.1-py2.7.egg\pc_ble_driver_py\ble_driver.py", line 117, in wrapper
        raise NordicSemiException('Failed to {}. Error code: {}'.format(wrapped.__name__, err_code))
    pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: 13
  • try: nrfutil dfu ble -pkg c:\Keil_v5\hello.zip -f
    i think there was no connectivity firmware on your DK
