services setup nrf8001
Services Setup
I am trying to feed the "Services Data" manually to the nRF8001.
As per the data sheet page 82 (see image below): Upon transmission of 1 packet of data an ACI_Transition_Continue should get generated: (i.e. some where a )"0x01" should get popped back to the Controller. If this is received then the controller should send out more packets, till the setup is complete.
image description
Now the first packet that I send out (after the nRF has been confirmed to be running is the standard packet:
{0x07,0x06,0x00,0x00,0x03,0x02,0x42,0x07};
The response is as follows:
image description
As you can see the sent in bytes just get echoed and there is no "01", instead I can see a "00" at the beginning (dont know if this means success ?).
In the next packet I sendout:
 {0x1f,0x06,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x06,0x00,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,};
Again, I assume this is a standard setup paket.
The result is 30 times "00". Same with all following messages.
Is there some thing I am doing wrong ? SPI is working without a problem and when I try to do ECHO every thing works fine.
I would be much obliged to you get your help.
