NRF52 PM_EVT_ERROR_UNEXPECTED problem with connection
hello,
I used nrf52 and softdevice 2.0.1 and i have a big problem.
For some times the BT works perfectly but after i connect more then 4 devices for some reason the device return PM_EVT_ERROR_UNEXPECTED end stop working. The reset do not help i used sd_nvic_SystemReset() and NVIC_SystemReset() even i trya power off the BT module, but this error still happens
i received this error(PM_EVT_ERROR_UNEXPECTED) every time when i want to connect to a BT module to a phone.
Any ideas what cause this.
  • I have discovered that after the records reach the bootloader_addr (0x77C00) the data continues to be written from address (0x74C00). I have also noticed that error PM_EVT_ERROR_UNEXPECTED appears in exactly this moment, when the records overlap form address (0x77C00) to (0x74C00).
  • #define CODE_PAGE_SIZE 0x1000
    #ifndef DFU_APP_DATA_RESERVED
    #define DFU_APP_DATA_RESERVED           CODE_PAGE_SIZE * 1
    This is the definition of the macro you are asking for.
    Where is placed the reserved data area?(I want to know where to place the application settings in order to be preserved during DFU).
  • It is reserved below the bootloader in flash. See this.Is your bootloader start address 0x77C00? I think you should set it to 0x77000 instead. Then you can leave DFU_APP_DATA_RESERVED to 0x1000, and the flash between 0x76000 and 0x77000 will be reserved for your data by the bootloader. It seems that Fstorage doesn't know know that you have in flash below 0x77000, so I think you should try to set FS_PAGE_END_ADDR manually. Try setting it to 0x76000, and see if that changes anything.
  • After we have changed the address as you suggested, I am not getting the error PM_EVT_ERROR_UNEXPECTED. But I observe strange behavior of the record mentioned above - the records are stored in pages starting (0x73000), (0x74000), (0x75000) - is that normal?
    Since before I change the addresses the flash(bootladder first page) was corrupted(I suppose), should I expect similar problems after the addresses were changed, because of this strange use of the pages?
  • Good. Yes, that is normal. Unmodifed, the Flash Data Storage module will use three flash pages. 1 swap page and 2 two for data. I didn't quite understand your last question, please elaborate.
1 2 3 4 5
