"Ideal" supply voltage for nRF52 to maximize efficiency?
I have the opportunity to select the voltage of the power supply feeding an nRF52. There no other chips in the system, thus there are no other constraints on the voltage. I realize that the nRF52 manages the usage of its internal LDO and DCDC converter; that's not the issue. Within the acceptable range of supply voltages for the chip, is there one which maximizes efficiency, taking into account the efficiency of the DCDC converter, etc.? If we were running only on the LDO, then a lower input would make sense, but the DCDC complicates the picture. I've not been able to find as much data on this topic as exists for the nRF51.
Thanks, Scott
  • Hi Øyvind,
    Would it be possible to get the online calculator with a "no dc/dc" option? And... pref. also at higher payloads.
    Since I'm in need of 1.8V I/O-logic, I'd like to understand if there is much benefit of (adding the extra inductors) using the internal dc/dc to just drop the last 1.8 -> 1.3V
    ps. any plans on offering a separate IO-domain in future nrf's? right now, using the internal regulators kind of assumes all peripheral ic's can support the same supply
