SPI rx problem
Hi guys,
I'm having some trouble with an spi flash memory (AT45DB081D) I interfaced on my nrf51 DK.
I used the spi master code of nRF5 v.12 SDK as base. I'm using gcc on a linux environment.
I can send commands and receive the proper answer from the flash memory. The problem is that the answer on the rx packet always comes preceded by some extra bytes or 0xFF or 0x00. And for each command comes a different amount of bytes, also I can't assure that the memory is programmed correctly.
I've tried many different configurations (changing the mode 0,1,2,3, changing the frequency, doing the cs independently) but nothing helped.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_gpiote.h"
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t       m_tx_buf[15];           /**< TX buffer. */
static uint8_t       m_rx_buf[15];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_rx_buf);        /**< Transfer length. */
bool spimem_read_device_id(void);
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event)
	spi_xfer_done = true;
	NRF_LOG_INFO("Transfer completed.\r\n");
void spimem_send_command(uint8_t sizetx, uint8_t sizerx)
  memset(m_rx_buf, 0xAA, m_length);
  spi_xfer_done = false;
  APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, sizetx, m_rx_buf, sizerx));
  while (!spi_xfer_done)
	  __WFE();
  if(sizerx!=0)
	NRF_LOG_INFO("Received[0]: %x %x %x %x %x %x \n\r",m_rx_buf[0],m_rx_buf[1],m_rx_buf[2],m_rx_buf[3],m_rx_buf[4],m_rx_buf[5]);
	NRF_LOG_INFO("Received[1]: %x %x %x %x %x %x \n\r",m_rx_buf[6],m_rx_buf[7],m_rx_buf[8],m_rx_buf[9],m_rx_buf[10],m_rx_buf[11]);
  NRF_LOG_FLUSH();
  m_tx_buf[0]=0x9F;
  spimem_send_command(1,4);
  return true;
bool spimem_read_status_register(void)
  m_tx_buf[0]=0xD7;
  return true;
bool spimem_ready(void)
  NRF_LOG_INFO("Reading status:");
  spimem_read_status_register();
  if(m_rx_buf[1]&0x80)
	NRF_LOG_INFO("Mem ready\r\n");
	return true;
	NRF_LOG_INFO("Mem busy\r\n");
  return false;
void spimem_read_flash(uint8_t *strtoread, uint8_t addr, uint8_t strsize)
  m_tx_buf[0]=0xD2; //Main memory read page
  m_tx_buf[1]=0x00;
  m_tx_buf[2]=0x00;
  m_tx_buf[3]=0x00;
  m_tx_buf[4]=0x00;
  m_tx_buf[5]=0x00;
  m_tx_buf[6]=0x00;
  m_tx_buf[7]=0x00;
  spimem_send_command(8,10);
  while(spimem_ready()==false);
void spimem_write_buffer(void)
  m_tx_buf[0]=0x84;
  m_tx_buf[1]=0x00; //dummy byte
  m_tx_buf[2]=0x00; //dummy byte
  m_tx_buf[3]=0x00; //addr byte on buffer
  m_tx_buf[4]=0xAC;
  m_tx_buf[5]=0x0C;
  m_tx_buf[6]=0x03;
  m_tx_buf[7]=0x04;
  m_tx_buf[8]=0x05;
  spimem_send_command(9,0);
void spimem_read_buffer(void)
  m_tx_buf[0]=0xD4;
  m_tx_buf[1]=0x00;
  m_tx_buf[2]=0x00;
  m_tx_buf[3]=0x00;
  m_tx_buf[4]=0x00;
  spimem_send_command(5,10);
	LEDS_CONFIGURE(BSP_LED_0_MASK);
	LEDS_OFF(BSP_LED_0_MASK);
	NRF_LOG_INFO("SPI example\r\n");
	nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
	spi_config.ss_pin   = SPI_SS_PIN;
	spi_config.miso_pin = SPI_MISO_PIN;
	spi_config.mosi_pin = SPI_MOSI_PIN;
	spi_config.sck_pin  = SPI_SCK_PIN;
	spi_config.frequency= NRF_DRV_SPI_FREQ_125K;
	spi_config.mode= NRF_DRV_SPI_MODE_0;
	APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler));
	NRF_LOG_INFO("\n\r\n\rRead Device ID\r\n");
	spimem_read_device_id();
	NRF_LOG_INFO("\n\r\n\rWrite Buffer\r\n");
	spimem_write_buffer();
	NRF_LOG_INFO("\n\r\n\rRead Buffer\r\n");
	spimem_read_buffer();
The return for that code is:
APP:INFO:SPI example
APP:INFO:
Read Device ID
APP:INFO:Transfer completed.
APP:INFO:Received[0]: ff 1f 25 0 aa aa
APP:INFO:Received[1]: aa aa aa aa aa aa
APP:INFO:
Write Buffer
APP:INFO:Reading status:APP:INFO:Transfer completed.
APP:INFO:Received[0]: 0 a4 88 a4 aa aa
APP:INFO:Mem ready
APP:INFO:
Read Buffer
APP:INFO:Received[0]: ff ff ff ff ff ac
APP:INFO:Received[1]: c 3 4 5 aa aa
On the command Device ID the first received byte (0xff) wasn't suppose to be there.
On the command Write Buffer, the verification of the buffer status also return a first strange byte (0x00), the following is all right.
On the command Read Buffer the first 5 bytes (0xff) weren't suppose to be there.
If anyone could help here I'd appreciate. Thank you all.
