I2C code conversion help needed
I need to read data from MLX90615. It is a temperature sensor which follows I2C to read data. I got a sample code for this which is given below.
float receiveTemperature(int Temperature_type) {
	int dev = (0x5B << 1);                               // 5B is the device address
	char dataLow = 0;                              // initially setting data low as zero
    char dataHigh = 0;                             // initially setting data high as zero
	char pec = 0;
	float celcius = 0.0;
	start(dev | I2C_WRITE);                        // start by sending device address
	write(Temperature_type);                       // choosing ambient or object temperature
	// read
	restart(dev | I2C_READ);                       // restart
	dataLow = read(false);                         // reading lower bytes
	dataHigh = read(false);                        // reading higher bytes
	pec = read(true);                              // reading packet error code
	stop();
	// This combines high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
	double resolutionFactor = 0.02;                // resolution factor of the MLX90614
	double temperature = 0x0000;
	int frac;                                      // data past the decimal point
	temperature = (double)(((dataHigh & 0x007F) << 8) | dataLow); // removes error bit of high byte by shifting and adds the low byte
	temperature= (temperature * resolutionFactor) - 0.01;         // multiplying temperature value with resolutionFactor
    celcius = (float)(temperature- 273.15);
	return celcius;                                               // return the value of temperature in celcius
In this, how can I change the API to nRF TWI drivers? I know the question is so stupid. But as a new comer the nRF APIs seems to be tougher for me.
