I use nRF51 DK and soft device s130.
I nedd to add a file ("app_uart_fifo.c") in the example of multilink central, after i add the file i build the proyect but the files .h never being created. I have to do something more?
If you want to use printf() function for UART, you need to add retarget.c to your project as well.
You need to set APP_UART_ENABLED in sdk_config.h if you use SDK v12. Your build output compains a lot about app_uart.c. You should not include this file if you include app_uart_fifo.c. There are no app_uart_fifo.h-file, you should use app_uart.h together with either app_uart.c or app_uart_fifo.c.
I fix the errors, i include uart in paths and i set APP_UART_ENABLED but i don't see app_uart.c nor app_uart_fifo.c. I put an image below about what keil show me now
Did you remove app_uart_fifo.c from your project again?
Yes i remove. Can i have to add again?
