Hi, I have the D52QD2M4IA-A chip (from dynastream) that has inside nrf52832 chip. It has also builtin an onboard LIS2DH accelerometer. However when I am trying to connect to it through SPI interface this seems not to respond back. Can Anyone help?
My code is as follows:
#include "nrf_drv_spi.h"
#include <stdbool.h>
#include <stdint.h>
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_temp.h"
#include "app_error.h"
#if defined(BOARD_PCA10040)
#define SPI_CS_PIN 27 /**< SPI CS Pin.*/
#elif defined(BOARD_PCA10036)
#define SPI_CS_PIN 29 /**< SPI CS Pin.*/
#elif defined(BOARD_PCA10028)
#define SPI_CS_PIN 4 /**< SPI CS Pin.*/
#else
#error "Example is not supported on that board."
#define SPI_INSTANCE 0
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
void spi_event_handler(nrf_drv_spi_evt_t const * p_event)
spi_xfer_done = true;
uint32_t err_code = NRF_SUCCESS;
uint8_t reg;
nrf_gpio_cfg_output(17);
nrf_delay_ms(1);
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG(SPI_INSTANCE);
spi_config.frequency = NRF_DRV_SPI_FREQ_1M;
spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_LSB_FIRST;
spi_config.ss_pin = SPI_CS_PIN;
nrf_delay_ms(1);
err_code = nrf_drv_spi_init(&spi, &spi_config, spi_event_handler);
nrf_delay_ms(1);
if (err_code != NRF_SUCCESS)
// Initialization failed. Take recovery action.
reg = 0x01;
uint8_t OUT_X_L_addr = 0x28; // The address of the register you want to write
uint8_t WHO_AM_I = 0x0F;
uint8_t tx_data[2] = {0x00, 0x00}; // Transmit register
uint8_t rx_data[2] = {0x00, 0x00}; // Receive register
while (true)
tx_data[0] = ( WHO_AM_I | 0x80 ); //Add the RW bit to the address.
spi_xfer_done = false;
nrf_delay_ms(1);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx_data, 2, rx_data, 2));
if (rx_data[1]>0){
nrf_gpio_pin_write(17,1);
nrf_delay_ms(1000);
nrf_gpio_pin_write(17,0);
nrf_delay_ms(500);
My code doesn't change the speed or the bit order, are you sure you need to change them ?
Also. The WHO_AM_I reg is 0x0F and you need to set the MSB for a read operation
PS. I ran my code in async mode, but that should not make any difference
Ok without changing the bit order I Was able to send WHO_AM_I reg (= 0x0F ) and to get back the value of 33. Now how I can go on to read more data? I am trying to read the OUT_X_L register but no lack (I am getting 00 value). Do I have to set something prior? Is there any sample code to get the xyz accelerometer values?
Well, you could read the technical reference
Or other people have written code for this device that you could port e.g.
I know this is a bit old, but for future reference, make sure you set the LIS2DH operation mode to low power, normal or high resolution before trying to read or you will get 0 when reading the axis values. By default it is in powered down mode. To do that write CTRL_REG1[3] (LPen) and CTRL_REG4[3] (HR) bits with your desired configuration.
