SDK 12.1.0 bootloader does not run application
I'm using the example bootloader from SDK 12.1.0 with gcc, nRF51822, S130. I flash the SD, bootloader and my application in that order like this:
flash: all
	$(NRFPROJ) --eraseall
	$(NRFPROJ) --program $(SOFTDEVICE)
	$(NRFPROJ) --program bootloader/biketracker_debug/armgcc/_build/bootloader_s130.hex
	$(NRFPROJ) --program $(HEX)
	$(NRFPROJ) --reset
When debugging the bootloader, I see this (with some extra logging I added in SDK sources)
:INFO:Inside main
:INFO:In nrf_bootloader_init
:INFO:In real nrf_dfu_init
:INFO:running nrf_dfu_settings_init
:INFO:Enter nrf_dfu_continue
:INFO:bank_current is NRF_DFU_CURRENT_BANK_0. Using bank_0.
:INFO:p_bank image_size: 0, image_crc: 0, bank_code: 0.
:INFO:Single: Invalid bank
:INFO:Application sent bootloader request
:INFO:In nrf_dfu_transports_init
:INFO:num transports: 1
:INFO:vector table: 0x00038000
SDH:INFO:sd_ble_enable: RAM START at 0x200025e0
:INFO:After nrf_dfu_transports_init
:INFO:------- nrf_dfu_flash_init-------
:INFO:Waiting for events
The first question is, should I be concerned that nrf_dfu_continue_bank() complains about "Single: Invalid bank". It looks like there's nothing in s_dfu_settings at all.
Secondly, this is a custom board and I have no buttons on it. nrf_dfu_enter_check() may be checking nrf_gpio_pin_read(BOOTLOADER_BUTTON) and reading a pin that I'm using for something completely unrelated. How do I override the implementation of nrf_dfu_enter_check()?
Edit 1
If I can get past that, I'll still need something valid here:
bool nrf_dfu_app_is_valid(void)
    NRF_LOG_INFO("Enter nrf_dfu_app_is_valid\r\n");
    if (s_dfu_settings.bank_0.bank_code != NRF_DFU_BANK_VALID_APP)
       // Bank 0 has no valid app. Nothing to boot
       NRF_LOG_INFO("Return false in valid app check\r\n");
       return false;
How is s_dfu_settings set? Here's a bit of my .Map file.
.bootloaderSettings
                0x000000000003fc00      0x400
 .bootloaderSettings
                0x000000000003fc00      0x400 /var/folders/dn/mqg_0vcj2zbfn7sp136z17gw0000gn/T//ccqgNNlW.ltrans4.ltrans.o
                0x000000000003fc00                m_dfu_settings_buffer
Edit 2
Having been enlightened to the need to generate a bootloader settings hex and flash it, I now find that even having done that, the bootloader sees 0x0 as the settings CRC and rewrites it.
Build output:
Generating bootloader settings hex.
~/Library/Python/2.7/bin/nrfutil settings generate --family NRF51 --application _build/biketracker_app_s130.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 _build/bootloader_settings.hex
Generated Bootloader DFU settings .hex file and stored it in: _build/bootloader_settings.hex
Bootloader DFU Settings:
* File:                 _build/bootloader_settings.hex
* Family:               nRF51
* CRC:                  0xD96D31B3
* Settings Version:     0x00000001 (1)
* App Version:          0x00000001 (1)
* Bootloader Version:   0x00000001 (1)
* Bank Layout:          0x00000000
* Current Bank:         0x00000000
* Application Size:     0x0001B6C8 (112328 bytes)
* Application CRC:      0x51B13C4A
* Bank0 Bank Code:      0x00000001
Erasing flash. Note that this will destroy any bonds on the device. Remember to also destroy them on the central (phone).
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --eraseall
Erasing code and UICR flash areas.
Applying system reset.
Programming soft device.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --program /Users/Eliot/dev/nRF5_SDK_12.1.0_0d23e2a/components/softdevice/s130/hex/s130_nrf51_2.0.1_softdevice.hex
Parsing hex file.
Reading flash area to program to guarantee it is erased.
Checking that the area to write is not protected.
Programing device.
Programming bootloader.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --program bootloader/biketracker_debug/armgcc/_build/bootloader_s130.hex
Parsing hex file.
Programing device.
Programming application.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --program _build/biketracker_app_s130.hex
Parsing hex file.
Programing device.
Erasing page for bootloader settings.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --erasepage 0x0003FC00
Erasing addresses 0x3FC00 to 0x3FFFF.
Programming bootloader settings.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --program _build/bootloader_settings.hex
Parsing hex file.
Programing device.
Reading back bootloader settings from 0x3FC00.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --memrd 0x3FC00 --n 0x60
0x0003FC00: D96D31B3 00000001 00000001 00000001   |.1m.............|
0x0003FC10: 00000000 00000000 0001B6C8 51B13C4A   |............J<.Q|
0x0003FC20: 00000001 00000000 00000000 00000000   |................|
0x0003FC30: 00000000 00000000 00000000 00000000   |................|
0x0003FC40: 00000000 00000000 00000000 00000000   |................|
0x0003FC50: 00000000 00000000 00000000 FFFFFFFF   |................|
Log from the bootloader, with some extra logging added:
:INFO:Inside main
:INFO:s_dfu_settings.crc: 0x0
:INFO:!!!!!!!!!!!!!!! Resetting bootloader settings !!!!!!!!!!!
:INFO:Erasing old settings at: 0x0003fc00
:INFO:Erasing: 0x0003fc00, num: 1
:INFO:Writing 0x00000057 words
:INFO:Writing settings...
:INFO:nrf_dfu_enter_check(): Returning false.
:INFO:Enter nrf_dfu_app_is_valid
:INFO:Return false in valid app check
