Halt on SOFTDEVICE_HANDLER_INIT after previous access of flash via nrf_nvmc driver
Hi all,
I am facing issues when initializing and enabling the Softdevice after using the nrf_nvmc driver to erase and write flash pages. The project shall have the ability to access write the flash before the Softdevice is enabled to update parts of our own bootloader.
In the steps to reproduce the crash on my system are:
  1. System startup
  2. Erasing a single flash page using nrf_nvmc_page_erase()
  3. Writing to the previouse erase flash page nrf_nvmc_write_words()
  4. Verify the written data -> successfull
  5. Erasing the flash page again using nrf_nvmc_page_erase()
  6. Initialize and enable the Softdevice via SOFTDEVICE_HANDLER_INIT()
The macro calls sd_softdevice_enable() within softdevice_handler_init(). Calling sd_softdevice_enable() halts the processor. Debugging with eclipse shows:
image description
When we remove the erasing and writting prior SOFTDEVICE_HANDLER_INIT() the Softdevice is enabled successfully. The code is running on nRF51 and nRF52 and we are facing the same problem.
Our setup is:
  • PCA10028 (V.1.0.0) and PCA10040 (V.1.1.0)
  • SDK 11
  • Softdevice S130 and S130 in Version 2.0.1
Any hints on that issue?
  • Hi vik, Can you upload the code where i can replicate it. I would be able to do more detail debugging as Ican dig into softdevice.
  • I created a small project for nRF51 to demonstrate the issue. With these few lines I can reproduce the problem.
    #include "nrf_nvmc.h"
    #include "softdevice_handler.h"
    int
    main (void)
        nrf_clock_lf_cfg_t clock_lf_cfg;
        const uint32 val = 0xAA55AA55;
        uint32 page = 130;
        uint32 page_adr = page * ((uint16_t)NRF_FICR->CODEPAGESIZE);
        kernelprintf ("\nErase page.\n");
        nrf_nvmc_page_erase((uint32) page);
        kernelprintf ("\nWrite word.\n");
        nrf_nvmc_write_words((uint32) page_adr, &val, (uint32) 1);
        if(*((uint32_t *) page_adr) != val)
            kernelprintf ("\nVerify failed.\n");
            kernelprintf ("\nVerify successful.\n");
        kernelprintf ("\nEnable Softdevice.\n");
        clock_lf_cfg.source        = NRF_CLOCK_LF_SRC_RC;
        clock_lf_cfg.rc_ctiv       = 32;
        clock_lf_cfg.rc_temp_ctiv  = 1;
        clock_lf_cfg.xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM;
        NVIC_ClearPendingIRQ(0xFFFFFFFF);
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        kernelprintf ("\nSoftdevice enabled.\n");
        while (1);
  • That is because you are erasing page 0.
    nrf_nvmc_page_erase((uint32_t) page); // where you set page = 130.
    This function does not take page number instead it takes start address of the page. Since you gave 130 to it, it understood that this is first page of the chip erase the vector table and part of MBR. So your application makes an SVC call (SOFTDEVICE_HANDLER_INIT->calls sd_softdevice_enable which is SVC), it never finds the SVC IRQ address in the vector table that you just erased inside page 0.
    your fix is below. change
    to
    nrf_nvmc_page_erase((uint32_t) page_addr);
  • Thank you, that was the solution. I first thought that my example project above was wrong but saw that I used the wrong argument page instead of p_page in my code. So it is obvious why the Softdevice crashes when erasing the wrong page ...
    Thank you.
  • Great. could you please accept this answer by clicking the ✓ on left of my answer. I recommend you to do the same when other help you, just to encourage them to help you faster.
