NRF_ERROR_INTERNAL while bonding?
After finding that Windows doesn't like HID devices if they can't be bonded to, I've been attempting to add peer_manager and bonding into my application.
However, having added it I'm getting loads of problems. I can connect normally, but:
Bonding (using nRF Connect) appears to work, but immediately after disconnecting, I get NRF_ERROR_NOT_FOUND from pm_whitelist_set in the BLE_GAP_EVT_DISCONNECTED handler (and the device resets).
Even after removing all the whitelist code (which I'm not too worried about), when attempting to bond I get NRF_ERROR_INTERNAL which comes via the PM_EVT_ERROR_UNEXPECTED handler (and the device also resets)
Any thoughts what could be the issue here? The internal error sounds a bit worrying.
The code that changed in order to add the peer manager without whitelist :
github.com/.../c969f3c52cb39cd0a66df6da4e22d61241486071...BLE_peer_manager_no_whitelist
Same code, but with the whitelist:
Is there anything obvious I've missed here? It kind of seemed like I'd got everything, but it's hard to tell from just looking through the HID example.
  • The fault identifier should be found in softdevice_fault_handler(), I now see that you included it in the case. I also see that you are getting help from a colleage of mine.
  • Thanks, yes - I just heard back today... I'd kind of assumed that you'd been doing both of them as last time you posted up just a few minutes after the issue's status had been set to 'assigned'. I'll post the answer up here when we get it completely fixed, but it looks like we've found the main problem.
  • Ok, there appear to be 2 main problems:
    Problem 1 - SDK v3 bug
    You can't call pm_whitelist_set while advertising or you get an internal error - this could also be to do with the fact that advertising_start would overwrite m_whitelist_peers, but it seems to be fixed on SDK v4. For v3 you just need to ensure that advertising is done after pm_whitelist_set. In this case it just meant swapping the order of some lines in the BLE_GAP_EVT_DISCONNECTED handler
    pm_evt_handler issue
    For some reason, when I paired as a BLE HID device under Windows 10, PM_EVT_CONN_SEC_SUCCEEDED got called twice (but only on W10, not on anything else). The example code provided doesn't check for duplicates, so m_whitelist_peers got 2 of the same handle ID in the list, which then caused BLE_ERROR_GAP_DEVICE_IDENTITIES_DUPLICATE when calling pm_whitelist_set. It just needs to check for duplicates before adding a new UUID.
    And that fixes the main issues I was having. There are still some more, but not related to this particular problem :)
    (And thanks for your help Håkon and Petter!)
