Handling Fds_write event before reading from flash.
I am having a 324 byte,a 420 bytes of array stored in flash,now i am updating these array with 360 bytes. in fds_event_handler in the case FDS_EVT_WRITE i am reading flash again
static void fds_event_handler(fds_evt_t const * const p_fds_evt)
    switch (p_fds_evt->id)
        case FDS_EVT_INIT:
            if (p_fds_evt->result != FDS_SUCCESS)
            // Initialization failed.
        case FDS_EVT_WRITE:
            if (p_fds_evt->result== FDS_SUCCESS)
                read_from_flash();
                write_flag = 1;
Ques: while reading i am getting last four or five rows values as zeros.
Suggestion: I am thinking that write event is not properly handled, means writing is not done properly.
Code for fds_read :
static ret_code_t fds_read(uint16_t record_read)
    fds_flash_record_t  flash_record;
    fds_record_desc_t   record_desc;
    fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
    float *data;
    uint32_t err_code;
    if(PRINT_DEBUG)
         NRF_LOG_PRINTF("Start searching... \r\n");
    // Loop until all records with the given key and file ID have been found.
    while (fds_record_find(FILE_ID, REC_KEY+record_read, &record_desc, &ftok) == FDS_SUCCESS)
         printf("in read:\n");
         err_code = fds_record_open(&record_desc, &flash_record);
         if ( err_code != FDS_SUCCESS)
             return err_code;
         if(PRINT_DEBUG)
         NRF_LOG_PRINTF("Found Record ID = %d reading record: %x,%d\r\n",record_desc.record_id,REC_KEY+record_read,record_read);
         NRF_LOG_PRINTF("Data = ");
     // Access the record through the flash_record structure.
     data = (float *) flash_record.p_data;
     int i=0;
     for(int j=0; j<(flash_record.p_header->tl.length_words)/COLUMNS_FOR_MODEL;j++)
         for(int k=0; k<COLUMNS_FOR_MODEL;k++,i++)
             model[j][k] = data[i];
             if(PRINT_DEBUG)
                 NRF_LOG_PRINTF("%f\t",model[j][k]);
     update_model(model,record_read);
     if(PRINT_DEBUG)
         NRF_LOG_PRINTF("\r\n");
     // Close the record when done.
     err_code = fds_record_close(&record_desc);
     if (err_code != FDS_SUCCESS)
         return err_code;
    return NRF_SUCCESS;
Code for fds_write:
static ret_code_t fds_write(float  model_array[][3],uint16_t record_write,uint16_t size_of_model)
    ftok.page=0;
    ftok.p_addr=NULL;
    fds_record_t        record;
    fds_record_chunk_t  record_chunk;
    record_chunk.p_data         = model_array;
    record_chunk.length_words   = size_of_model*3;
    // Set up record.
    record.file_id              =  FILE_ID;
    record.key                  =  REC_KEY+record_write;
    record.data.p_chunks        =  &record_chunk;
    record.data.num_chunks      =  1;
    if(fds_record_find(FILE_ID, REC_KEY+record_write, &record_desc, &ftok) == FDS_SUCCESS)
         fds_record_delete(&record_desc);
         ret = fds_gc();
         fds_record_update(&record_desc,&record);
    NRF_LOG_PRINTF("%d\n",record_write);
    return NRF_SUCCESS;
Using the same write code i am able to write into flash if i clear the flash first.and able to read also.
I just need that at run time Fds_write should update flash and fds_read able to read from flash properly after write and then other function should work.
Any help would be appreciated.
  • Ok. Maybe you can include some code that shows how you are doing this? I'm guessing it has changed from the code in the question?
  • I have found that during fds_record_update i was not providing the record_desc.record_id. that is why it was giving record not found.Now i am able to update. But the issue of last few bytes not been written is still there. I am attaching updated fds_write code
    	record_desc.record_id       =  record_write+1;//imp line when you are using fds_record_update.
    	ret_code_t ret;
    	ret = fds_record_update(&record_desc,&record);
    	return ret;
  • And how are you testing this? How are you using fds_write()? What arguments do you give to the function?
  • arguments given to fds_write() are a 2 dimensional array,record_write parameter which will add to 0x2222 to get record key.size of model this is actually number of rows in model_array which will be multiplied by 3 to give the length_words.
    i am testing this when I am reading from flash. i verified at every point that the data is not corrupted till the function fds_write() is called. means i am getting proper values of array before giving to fds_write().
    in the last 5 rows i am getting back zero,but there should be some value.
  • It is difficult to understand what you are doing with the record keys, I don't understand why you are changing them. Anyways, could you zip your complete project, edit the question and attach it there? So I can test it here? Also, what SDK and SoftDevice version are you using?
