nRF51: Timer Capture Task
I want to measure a frequency of a PWM signal like this:
GPIOTE-Event --> PPI --> Timer1-Capture-Task
So every time the event occurs, the counter value is copied into the respective CC-Register (in my case channel 0).
Question: Where is the ideal place to copy the content of the CC-Register into, lets say a data array? Normally, I would assume, that the Timer gererates an interrupt as soon as it has finished the capture. So my first idea is to use the timer ISR to copy the value. BUT: What is the advantage of that technique compared to a normal GPIO-Interrupt-ISR and reading/capturing the timer value manually in that ISR? (without using GPIOTE and PPI)?
Second question: How can I achive a timer clear as soon as the capture is done?
This is my code so far:
  uint32_t err_code;
  err_code = nrf_drv_timer_init(&timer, &timer_cfg, timer_dummy_handler);
  #ifdef NRF51
    //Workaround for PAN-73.
    *(uint32_t *)0x40008C0C = 1;
  uint32_t gpiote_evt_addr;
  uint32_t capture_task_addr;
  nrf_ppi_channel_t ppi_channel;
  nrf_drv_gpiote_in_config_t config;
  config.sense = NRF_GPIOTE_POLARITY_LOTOHI;
  config.pull = NRF_GPIO_PIN_NOPULL;
  config.is_watcher = false;
  config.hi_accuracy = true;
  nrf_drv_gpiote_in_init(SIG_PIN,&config, gpiote_evt_handler);
  err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
  capture_task_addr = nrf_drv_timer_task_address_get(&timer, NRF_TIMER_TASK_CAPTURE0);
  gpiote_evt_addr = nrf_drv_gpiote_in_event_addr_get(SIG_PIN);
  err_code = nrf_drv_ppi_channel_assign(ppi_channel, gpiote_evt_addr, capture_task_addr);
  err_code = nrf_drv_ppi_channel_enable(ppi_channel);
  nrf_drv_gpiote_in_event_enable(SIG_PIN, true);
  nrf_drv_timer_enable(&timer);
  while(1)
Thank you very much in advance!
