How to make it run application when there is a bootloader in the nRF52
I'm using the bootloader in nRF5_SDK V12.0 with nRF52832. I have some problems want to know:
  1. How to make it run application first after I program softdevice,bootloader and application? I found that it runs the bootloader and broadcast as "DfuTarg". I know it can set m_boot_settings in nRF5_SDK V11.
  2. After I finish the OTA, it can run the application. However, if I just do a little modification in my application and then program it, it would neve run the application,it runs the bootloader. Is it normal?
  3. I want to use AT command received by the UART to make it switch to bootloader instead of using a button. I do that like this: In my application,when received the AT command, I will write a value to the flash(the last page in the flash) using fstorage then do a reset. In the bootloader, I add some code to read the flash to check the value. So my question is I should use the fstorage or do it like flashwrite example in SDK? Which way would you suggest? Thanks.
