Hi Nordic, we need to modify bootloader code base on your dfu example. Now We meet a problem that we can't program it by clicking icon "Load" on keil comile project. report error as below:
Programing device.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
nrfjprog.exe --program "D:\project\SPW07A\Bootloader_Code\examples\dfu\bootloader\pca10040\dual_bank_ble_s132\arm5_no_packs\_build\nrf52832_xxaa_s132.HEX" -f NRF52 --chiperase --log
Parsing hex file.
Erasing code and UICR flash areas.
Applying system reset.
Checking that the area to write is not protected.
Programing device.
according to error's hint, I add --log after --program "#H" -f NRF52 --chiperase --log and get the log text. pls refer the attached file.JLinkARM.log.txt but i can't find the reason. if we use the same project to program it on EVB PCA10040, it is ok. why ? Is the different between the EVB PCA10040 's JLINK and our JLINK cause the issue? how to fix it? Thanks.
