how to use HANDLE RANGE correctly for Multiconnection ?
good time dear Engineers!
Please explain how to use correctly HANDLE RANGE in functions of discovering. I use CENTRAL with up to 8 possible connections to PERIPH, so pls explain following:
sd_ble_gattc_primary_services_discover(conn_handle, start_handle, &uuid);
WHAT IS start_handle if 8 Active Connections co-exist ? why it is always 0x0001 ?
sd_ble_gattc_characteristics_discover(conn_handle, p_handle_range);
WHAT is p_handle_range if 8 ACTIVE CONNECTIONS ? for example, for 2 connections: if conn_handle1=0x0 and conn_handle2=0x1 ?
sd_ble_gattc_descriptors_discover(conn_handle, p_handle_range);
for different connections handles (0x0,0x1,etc..), must p_handle_range be different too ? e.g.
conn_handle1=0x00: p_handle_range  = {0x10,0x15}
conn_handle2=0x01: p_handle_range  = {0x20,0x25}
etc.. ?
How to Manage Handle Ranges in case of Disconnecting -> Connencting -> Discovering again , etc... correctly (in this cases old handles must be re-assigned again) ?
I have one SERVICE (1666) two CHAR's (d5aa, d780) in this service and 4 Descriptors in each CHAR.
I found SERVICE, CHARS and store it's HANDLEs in my database according to the Photo. Q: how to find all descriptors in each CHAR's ? What valid handle_range I should use as PARAMETER to sd_ble_gattc_descriptors_discover(...) ?
image description
if I use handle_range of [e.g. 0x09 - 0x0E] means from service start_ handle to last char handle_value , seems it's OK, all the Attribute founds success.
  • The handle_decl is the handle ID of the declaration, it should always is the first attribute of a characteristic. Come after that should be the value and descriptor(s) if any. This doesn't make much sense:
    connection[0].service[0].char[0].handle_value=0x000a; // to acces for read/write operations. connection[0].service[0].char[0].handle_decl =0x000b; // to acces for ??????? what ?
    handle_decl should be < handle_value
    In the figure you provided, the handle_decl and handle_value look more correctly.
    The descriptor is located after the value handle ID till the next characteristic/service, in other words, between the current handle_value and the next handle_decl.
    You can use nRF Master Control Panel to do a service discovery, you can have a clear view of how your attribute table looks like.
  • Dear Hung! sorry for my 'copy-past' mistake with incorrect (handle_decl < handle_value), I fixed. now is fully CLEAR. Thanks you very much!
  • I changed the figure to right solution.
