bootloader + watchdog for mbed
I am trying to modify the default mbed bootloader to include support for watchdog. I'm running with nRF51822AC (NRF51DK). My program is written with mbed classic (uses S130v1) and I'm using mbed CLI. The main issue I'm experiencing is that replacing the default bootloader that comes with mbed (s130_nrf51_1.0.0_bootloader.hex, 35K) with say, the dfu bootloader example from SDK 10 (/examples/dfu/bootloader/pca10028/dual_bank_ble_s130/) causes the device to hang and the application doesn't start. What I've done was simply to replace the default file with my newly compiled one (~41K). Is that suppose to work, or has mbed introduced some special things in their bootloader? If not, is this somehow related to predefined offsets in the target definition json file?
I am also not sure what source code was used to create the default mbed bootloader (ideally, I would just change that one). I looked at some forums and it seems like this might be the repo: github.com/.../nrf5x-dfu-bootloader, but I was not able to compile it (arm-none-eabi-gcc with osx, I get the following errors):
Scanning dependencies of target BLE_BOOTLOADER.elf
[  8%] Building C object CMakeFiles/BLE_BOOTLOADER.elf.dir/main.c.o
arm-none-eabi-gcc: error: unrecognized command line option '--c99'
arm-none-eabi-gcc: error: unrecognized command line option '--cpu=Cortex-M0'
arm-none-eabi-gcc: error: unrecognized command line option '--apcs=interwork'
arm-none-eabi-gcc: error: unrecognized command line option '--enum_is_int'
arm-none-eabi-gcc: error: unrecognized command line option '--md'
arm-none-eabi-gcc: error: unrecognized command line option '--feedback=.feedback'
make[2]: *** [CMakeFiles/BLE_BOOTLOADER.elf.dir/main.c.o] Error 1
make[1]: *** [CMakeFiles/BLE_BOOTLOADER.elf.dir/all] Error 2
make: *** [all] Error 2
If anyone went through this hassle before and managed to get a new bootloader that works with mbed's S130v1, please contact me. I really need some help on this.
Thank you!
Shay
  • Hi Shay, could you elaborate when you say that the bootloader does not accept incoming updates? Are you using one of our apps to perform the update? Do you get any errors or does it simply disconnect? Do you want to keep the discussion in this question or in this question?
  • Hi Bjorn. Thank you for the follow up. I have worked on this for quite a while and I still can't get the original bootloader project from mbed to compile. I talked to the mbed team and they said they no longer support S130 v1.0.0. After fiddling around over the weekend, I was able to use the vanilla bootloader from SDK 10. It only accepts v0.8 bootloader updates, so I ended up figuring out how to send these updates from my code. For some reason, nrftoolbox failed to send updates, but my code did mange to. I think it's again something related to the expected bootloader version but I didn't pursue this further as things seem to be working now.
  • Hi Shay, what DFU version have you set in the DFU service included in your application?
