GPIOTE Interrupt nRF51822 freezing
I am writing a firmware for one of my custom boards which use GPIOTE to detect interrupt for 3 GPIOs inputs (P0.03, P0.06 and P0.09, both with internal pull-ups) and one pin set as an output (P0.05). Everything is working perfectly until the P0.09 pin goes low, then the device is freezing and does not respond to any interrupt.
I tried to debug this problem using RTT by asking to write a line when the P0.09 interrupt happens, but I never saw this line.
First, I initialize the gpiote module and the gpiote output on P0.05, and set it to 1 :
// Initialize the GPIOTE Peripheral
nrf_drv_gpiote_init();
// Configure P0.05 pin as output
nrf_drv_gpiote_out_config_t p5_config = GPIOTE_CONFIG_OUT_TASK_HIGH;
// Initialize P0.05 pin as output
nrf_drv_gpiote_out_init(5, &p5_config);
nrf_drv_gpiote_out_set(5);
Here as the configuration for the gpiote pins :
// Configuration for P0.06 Interrupt Pin
    nrf_drv_gpiote_in_config_t p6_config =
        .sense = NRF_GPIOTE_POLARITY_LOTOHI,
        .pull = NRF_GPIO_PIN_PULLUP ,
        .is_watcher = false,
        .hi_accuracy = false
    // Configuration for P0.03 Interrupt Pin
    nrf_drv_gpiote_in_config_t p3_config =
        .sense = NRF_GPIOTE_POLARITY_HITOLO,
    // Configuration for the P0.09 Interrupt Pin
    nrf_drv_gpiote_in_config_t p9_config =
Then I init and enable each GPIOTE interrupt :
// Initialize P0.06 Interrupt Pin
    nrf_drv_gpiote_in_init(6, &p6_config, gpiote_evt_handler);
    // Enable Interrupts from P0.06 interrupt pin
    nrf_drv_gpiote_in_event_enable(6,true);
    // Initialize P0.03 Interrupt Pin
    nrf_drv_gpiote_in_init(3, &p3_config, gpiote_evt_handler);
    // Enable Interrupts from P0.03 interrupt pin
    nrf_drv_gpiote_in_event_enable(3,true);
    // Initialize P0.09 Interrupt Pin
    ret_code_t ret_code;
    ret_code = nrf_drv_gpiote_in_init(9, &p9_config, gpiote_evt_handler);
#if defined(NRF_LOG_USES_RTT) && (NRF_LOG_USES_RTT == 1)
    if(ret_code == NRF_SUCCESS)
			SEGGER_RTT_WriteString(0, "P0.09 GPIOTE init state : NRF_SUCCESS.\n");
    else if(ret_code == NRF_ERROR_INVALID_STATE)
			SEGGER_RTT_WriteString(0, "P0.09 GPIOTE init state : NRF_ERROR_INVALID_STATE.\n");
    else if(ret_code == NRF_ERROR_NO_MEM)
			SEGGER_RTT_WriteString(0, "P0.09 GPIOTE init state : NRF_ERROR_NO_MEM.\n");
			SEGGER_RTT_printf(0, "P0.09 GPIOTE init state : %ld.\n", (uint32_t)ret_code);
    // Enable Interrupts from P0.09 interrupt pin
    nrf_drv_gpiote_in_event_enable(9,true);
With this configuration, all the GPIOs are doing perfectly their jobs excepted when the P0.09 interrupt occurs, which freezes everything. The intialization of the gpiote input for P0.09 returns NRF_SUCCESS, and the following channels are used for each GPIOTE event (returned by channel_port_alloc function during the initializiation of the gpiote pin events) :
  • P0.05 : channel 0
  • P0.06 : channel 4
  • P0.03 : channel 5
  • P0.09 : channel 6
That all the informations that seemed useful to me about this problem. I am working on a nRF51822 QFACA1, with SDK v11.0.0 and softdevice s130 nrf51 v2.0.0.
Do you have an idea of how to solve this problem ?
Guillaume
