sd130 and sdk12.1.0 ble bootloader problem
I'm sorry. I closed this question and can't reopen. I need more answer. If I solve all problem I'll close this question.
As you mentioned I'll try HW version modification. And I'll add the result.
I have some problem in DFU. I ask this again. I did as below.
  1. private key generation nrfutil keys generate c:\vault\priv.pem
  2. public key generation in code format nrfutil keys display --key pk --format hex c:\vault\priv.pem nrfutil keys display --key pk --format code c:\vault\priv.pem nrfutil keys display --key pk --format code c:\vault\priv.pem --out_file dfu_public_key.c
  3. experimental_ble_app_buttonless_dfu project compile and package file make nrfutil pkg generate --hw-version 1 --sd-req 0x87 --application-version 4 --application nrf51422_xxac.hex --key-file key.pem app_dfu_package.zip
  4. bootloader_secure compile with dfu_public_key.c(made in process 2) and bootloader setting file make nrfutil settings generate --family NRF51--application nrf51422_xxac.hex --application-version 3 --bootloader-version 2 --bl-settings-version 1 settings.hex
  5. merge bootloader and settings hex file mergehex -m nrf51422_xxac_s130 settings.hex -o output_file.hex
  6. SD130 / output_file.hex program into PCA10028 Board after erase all
  7. I try DFU in android phone. I can see DfuTarg. But, It fails to DFU app_dfu_package.zip(made in process 3).
What’s wrong? I don’t know.
**I want DFU process as below.
  1. my application run when power on
  2. bootloader enter(using buttonless_dfu projecs - Already I merged with my application.) after some key input (This key is in my custom board.)
  3. upload my new F/W using bootloader_secure in android phone.
  4. my new application run again after DFU done.**
I need your help eagerly.
  • Sure, I did that. I'll explain what I did.
    1. application.hex package make
    2. bootloader.hex make
    3. bootloader settings.hex make
    nrfutil settings generate --family NRF51 --application bootloader.hex --application-version 3 --bootloader-version 2 --bl-settings-version 1 settings.hex
    1. mergehex -m bootloader.hex settings.hex -o boot_set.hex
    2. I flash SD130 / application.hex / boot_set.hex.
    3. After repower on I can see DfuTarg scanned in the nrf toolbox.
    Application doesn't any BLE operation. It just waits Key input to enter bootloader.
    Is there anything wrong?
  • Yes, you have to provide the application hex file, not the bootloader.hex file when generating the settings page. nrfutil will calculate the CRC of the application image and store that in bootloader settings. On startup the bootloader will compare the CRC of the application in flash and the CRC that is stored in the bootloader settings page. If they match then the application will start otherwise the device will stay in bootloader mode.
  • I saw the application run when 1st power on after sd130/application/bootloader flashing.
    I made a mistake in making settings file.
    I close this issue.
    I greatly appreciate you.
