Proper way to start/stop advertising?
It seems like this should be a simple thing, but I can't find an example of it, and nothing I've read here seems to help.
I want my app to come up in general advertising mode and stay there, forever, until certain things happen. Then I want it to shut down to a reasonably low-power state (nothing running but timers) until a button is pressed, at which time it will wake up and start advertising again, and then stop again, etc.
But when I call sd_ble_gap_adv_stop(), it returns a bad state error if it doesn't happen to be advertising at the moment (I assume that means between intervals), but if I ignore that error the program then fails with a timer memory error (trying to do an m_evt_schedule_func(), which I assume is the next advertisement).
I guess what I really want is advertising always on, but in "IDLE" mode sometimes. But I don't see any way to do that with softdevice calls. Can sd_ble_gap_adv_start() be called more than once with different parameters, maybe? Can I shutdown and restart the whole softdevice?
My startup code (using SDK 12.1) is:
void advertising_start()
    ble_gap_conn_sec_mode_t         sec_mode;
    ble_gap_conn_params_t           gap_conn_params = {
        .min_conn_interval = MIN_CONN_INTERVAL,
        .max_conn_interval = MAX_CONN_INTERVAL,
        .slave_latency = SLAVE_LATENCY,
        .conn_sup_timeout = CONN_SUP_TIMEOUT
    ble_advdata_t                   adv_data = {
	    .name_type = BLE_ADVDATA_FULL_NAME,
	    .include_appearance = false,
	    .flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE
    static ble_gap_adv_params_t     adv_params = {
	    .type = BLE_GAP_ADV_TYPE_ADV_IND,
	    .p_peer_addr = NULL,
	    .fp = BLE_GAP_ADV_FP_ANY,
	    .interval = APP_ADV_INTERVAL, // 100 ms
	    .timeout = 0
    APP_ERROR_CHECK(sd_ble_gap_device_name_set(&sec_mode,
				      (const uint8_t *)P.bt.device_name,
				      strlen(P.bt.device_name)));
    APP_ERROR_CHECK(sd_ble_gap_ppcp_set(&gap_conn_params));
	APP_ERROR_CHECK(ble_advdata_set(&adv_data, NULL));
	APP_ERROR_CHECK(sd_ble_gap_adv_start(&adv_params));
