SPI failure in case of modifications to unrelared code segment
Hi everyone,
I am using nrf52832 with SDK version 11.0 for an IoT application. I am communicating with Atmel ATWINC 1500 module through SPI in order to connect to Wifi. My code was working fine until I added few new lines of code unrelated to SPI. Now when I run the project on Nordic hardware I get following SPI read errors.
(APP)(ERR)[spi_data_read][385][nmi spi]: Failed data response read...(00) (APP)(ERR)[spi_read_reg][625][nmi spi]: Failed data read...
I know that this error occurs when there is some issue with pin assignment for SPI interface but I have verified all the pin assignments. The stranger thing is that the project starts working fine if I comment out any part of the project totally unrelated with SPI. Following are the results when I compile the project using Eclipse.
'C:/Program Files (x86)/GNU Tools ARM Embedded/5.4 2016q3/bin/arm-none-eabi-size' _build/nrf52832_xxaa.out text data bss dec hex filename 56312 1436 37904 95652 175a4 _build/nrf52832_xxaa.out
It might be a memory issue or some other issue. I have tried debugging it but failed so any leads or suggestion about where the problem might be or how to debug such an issue will be highly appreciated. My Make file and start up file is attached.
arm_startup_nrf52.s Makefile
  • Enabling that workaround fixes the problem.  Thanks!
    We did not consider this workaround required because the the transmit and receive buffers are not touched by the CPU when the SPI transfer is in progress.  Perhaps the ambiguity is in what is meant by "same RAM block" in the errata description.  Perhaps you can describe in more detail what is meant by this phrase in this context since it is apparently a block that is larger than the buffer used by the SPI peripheral.  Does the "RAM block" mean "RAM section" as laid out in section 4.2.1 of the nRF52840 datasheet?  Or "RAM AHB slave"?
  • : Great! The CPU does not have to touch the buffers the bug may occur when the CPU is writing or reading to the same RAM block as where the SPI3 DMA buffers at the same time as the SPIM is fetching data from RAM.
     By different RAM Block we mean different RAM AHB Slave.
    Best regards
    Bjørn
