ble_app_template.zipI need to setup whitelist. To achieve that while calling ble_advertising_init I specified
ble_adv_whitelist_enabled = true
then, while handling BLE_ADV_EVT_WHITELIST_REQUEST I use:
uint32_t err_code;
ble_gap_addr_t whitelist_addr = {1, BLE_GAP_ADDR_TYPE_RANDOM_STATIC, {0x25,0xD7,0x90,0x11,0x7A,0xC8}};
const ble_gap_addr_t *p_whitelist_addr[] = {&whitelist_addr};
switch (ble_adv_evt)
case BLE_ADV_EVT_WHITELIST_REQUEST:
err_code = sd_ble_gap_whitelist_set(p_whitelist_addr, 1);
err_code = ble_advertising_whitelist_reply(NULL, 1, NULL, 0);
I made sure that both err_codes above are 0 once those 2 functions return but all this results in no advertising, instead I am experiencing (in RTT Viewer) APP_ERROR:ERROR:Fatal. If I commented out content of the 'case' above - then my device is advertising.
Did I miss anything while setting up my whitelist?
I think I did everything as described in Software Development Kit > nRF5 SDK > nRF5 SDK v12.2.0 > Libraries > BLE libraries > Advertising Module > Whiltelist > Usage
which says:
If you are using the S13x SoftDevice v3.x, call sd_ble_gap_whitelist_set. Then, call ble_advertising_whitelist_reply (you only need to provide the counts)
in my case I am using S132 V3.1.0
Update
I tried to grab error details but Keil (?) is experiencing encoding issues while trying to display the file name, I don't have such a problem with at least files I create myself and main.c
The project can be found in the attachment.
