Unwanted disconnection after notification
I am trying to write a program which send data through notification. All is working, excepted that once the notifications are done, the device automatically disconnects after a few seconds. And there is no possibility to write nor read the other characteristics between the end of the notifications and the disconnection. Once the device is disconnected, I am able to connect to it again and perform read and write, but the same problem still happens when I want to receive notification.
My target is a nRF51822-QFACA1, I use sdk v11 and softdevice s130 v2.0.0
Edit 01/03/2017 : Here is the information I catched with a sniffer, about the message which has been sent at the same moment than the disconnection event :
www.hostingpics.net/viewer.php
Could you help me to solve this problem ?
Guillaume
  • Hi Guillaume,
    From the trace I can see that it's not disconnect right after you send notification. What you capture in your image in the question is the LL_TERMINATE_IND packet which mean it's the termination packet from the Master/central to disconnect.
    The disconnection happen 30 second after a write request (packet 637) it's a timeout for the write request because there is no write response for it.
    Usually this happens when you set a characteristic with authorization and in the application you don't response to the BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST event. Please have a look here.
    The write request is for attribute at handle ID 0x0f, you may want to check. Same write response to handle 0x10 (packet 302)had no issue.
  • Thanks a lot ! I forgot to set one parameter that is needed for sd_ble_gatts_rw_authorize_reply, so this function returns the error NRF_ERROR_INVALID_PARAM and doesn't send the reply.
