Can't instantiate uart driver
Hello all,
I try to instantiate an uart driver using NRF_DRV_UART_INSTANCE macro, but I got the following error :
sdk/components/drivers_nrf/uart/nrf_drv_uart.h:97:1: error: invalid conversion from 'void*' to 'NRF_UARTE_Type*' [-fpermissive]
drivers/uart.hpp:41:27: note: in expansion of macro 'NRF_DRV_UART_INSTANCE'
     nrf_drv_uart_t uart = NRF_DRV_UART_INSTANCE(0);
bellow is my code :
#include "nrf_drv_uart.h"
#include "app_error.h"
#include "nrf.h"
void uartEventHandler(nrf_drv_uart_evt_type_t *p_event)
void initUART()
    uint32_t err_code;
    nrf_drv_uart_config_t uart_cfg;
    uart_cfg.pseltxd=RX_PIN_NUMBER;
    uart_cfg.pselrxd=TX_PIN_NUMBER;
    uart_cfg.pselcts=RTS_PIN_NUMBER;
    uart_cfg.pselrts=CTS_PIN_NUMBER;
    uart_cfg.hwfc=UART_CONFIG_HWFC_Disabled;
    uart_cfg.parity=false;
    uart_cfg.baudrate=UART_BAUDRATE_BAUDRATE_Baud115200;
    uart_cfg.use_easy_dma = true;
    err_code = nrf_drv_uart_init(&uart, &uart_cfg, uartEventHandler);
    nrf_drv_uart_rx_enable(&uart_cfg);
thank you in advance for help ! there is my sdk config file : sdk_config.h my toolchain : arm-gcc-none-eabi-4.9-2015q3. my main.cpp file : main.cpp
  • What if you do:
    #define NRF_DRV_UART_INSTANCE(id)                            \
        .reg          = {p_uart = NRF_DRV_UART_PERIPHERAL(id)},           \
        .drv_inst_idx = CONCAT_3(UART, id, _INSTANCE_INDEX),\
    or
        .reg          = {p_uart = (NRF_UART_Type*)NRF_DRV_UART_PERIPHERAL(id)},           \
    instead of
        .reg          = {NRF_DRV_UART_PERIPHERAL(id)},           \
  • hello, that's compile, I also modify this code part :
    typedef struct
        union
    #if (defined(UART_IN_USE) || (UART_ENABLED == 0))
        NRF_UART_Type * p_uart;   ///< Pointer to a structure with UART registers.
    #if (defined(UARTE_IN_USE))
        NRF_UARTE_Type * p_uarte; ///< Pointer to a structure with UARTE registers.
        } reg;
        uint8_t drv_inst_idx;     ///< Driver instance index.
    } nrf_drv_uart_t;
    and I suppress the p_uart = in the NRF_DRV_UART_INSTANCE macro. As I said, the program compile, but it didn't work, this is my main function :
    #define BSP_UART_SUPPORT #include "bsp.h" #include "sdk_config.h" #include "nrf_delay.h"
    const nrf_drv_uart_t uart_test = NRF_DRV_UART_INSTANCE(0);
    void uart_event_handler(nrf_drv_uart_event_t * p_event, void * p_context) { //static uint8_t rec_byte=0; switch(p_event->type) { case NRF_DRV_UART_EVT_RX_DONE:
        case NRF_DRV_UART_EVT_ERROR:
    int main(void) {
    /*Parameters for uart driver*/
    uint32_t err_code;
    uart_cfg.pseltxd        = RX_PIN_NUMBER;
    uart_cfg.pselrxd        = TX_PIN_NUMBER;
    uart_cfg.pselcts        = RTS_PIN_NUMBER;
    uart_cfg.pselrts        = CTS_PIN_NUMBER;
    uart_cfg.hwfc           = NRF_UART_HWFC_DISABLED;
    uart_cfg.parity         = NRF_UART_PARITY_EXCLUDED;
    uart_cfg.baudrate       = NRF_UART_BAUDRATE_115200;
    err_code = nrf_drv_uart_init(&uart_test,&uart_cfg,uart_event_handler);
    nrf_drv_uart_rx_enable(&uart_test);
    uint8_t test[4]={0,255,0,255};
    static uint8_t i=0;
    while( true )
      while(i<4)
          err_code = nrf_drv_uart_tx(&uart_test, &test[i], 1);
          if(err_code ==NRF_SUCCESS )
          nrf_delay_ms(1000);
          i++;
      i=0;
    return 0;
    in the oscilloscope, I don't have any signal in Tx output pin :/
