Hi, Im using Nrf51422 DK board. When I try the ble_app_multilink_central example in the SDK12, it works on the DK board. But it does not work in NRF51822. (NRF51822 QFAA)
I tried the settings on this link but it did not. Link
Help me please.
Help me please.
Hi~ I have the same problem, but can you tell me how to "reduce the number of peripheral connections from 8 to 4"? I change "N_WRITE_BUFFERS" from 8 to 4, but ZI-data only reduced 400, so which one is the correct setting?
Which SDK are you using @samsc?
Hi ~ i'm using SDK 12.3.0_d7731ad
The solution above appears to apply to SDK v12.0.0 only, if I use the same settings in SDK v12.3.0 then I am not able compile the project, i.e. the libraries/drivers used in the example has grown in size since the SDK v12.0.0 release. I am able to compile the SDK v13.0.0 if I set the CENTRAL_LINK_COUNT to 2.
thanks for the reply, let me have a test by setting CENTRAL_LINK_COUNT to 2 and let you know the result.
