Hello, My problem is to much current c.a. 40uA in POWER OFF mode. Below attach code:
void power_down()
nrf_gpio_pin_clear(22); // Wylacz mostek tensometryczny
nrf_delay_ms(10);
nrf_gpio_pin_clear(20); // Wylacz LDO 2V5
nrf_delay_ms(10);
timer_disable();
saadc_sampling_event_disable();
sd_clock_hfclk_release();
// Disable TWI ready for sleep
NRF_TWI0->ENABLE= TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
// shut down the dcdc
sd_power_dcdc_mode_set(NRF_POWER_DCDC_DISABLE);
sd_power_system_off();
nrf_gpio_cfg_output(20); // Ustaw EN LDO jako output
nrf_gpio_pin_set(20); // Wlacz LDO
nrf_gpio_cfg_output(22); // Ustaw mosfet jako output
nrf_gpio_pin_set(22); // Wlacz mostek tensometryczny
nrf_gpio_cfg_input(14, NRF_GPIO_PIN_PULLUP); // Ustaw mosfet jako input
nrf_gpio_cfg_input(3, NRF_GPIO_PIN_PULLUP); // Ustaw jako wejsicie INT1 z MMA8452
nrf_gpio_cfg_input(18, NRF_GPIO_PIN_PULLUP); // Ustaw jako wejsicie INT2 z MMA8452
// ANT+ init
uint32_t err_code;
utils_setup();
softdevice_setup();
ant_state_indicator_init(m_ant_bpwr.channel_number, BPWR_SENS_CHANNEL_TYPE);
simulator_setup();
profile_setup();
// This pin is used for waking up from System OFF and is active low, enabling sense capabilities.
nrf_gpio_cfg_sense_input(PIN_GPIO_WAKEUP, BUTTON_PULL, NRF_GPIO_PIN_SENSE_LOW);
//Enable DCDC
err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
// Workaround for PAN_028 rev1.1 anomaly 22 - System: Issues with disable System OFF mechanism
nrf_delay_ms(1);
// TWI
twi_init();
//HMC5883L_init();
//MMA8452Q_init();
// SAADC
saadc_sampling_event_init();
saadc_init();
while(FORCE_SLEEP == 0)
__SEV();
__WFE();
__WFE();
power_down();
I think that any pherips is disabled... No chips connected to TWI. I would be gratefull for help.
