Problem with sd_ble_gatts_hvx without notifications enabled
Hi there!
I am trying to add custom UUID's for my BLE application. I have a custom service which has 2 RX and 3 TX characteristics.
I have a situation where the Android APP that I am using doesn't notify. Because of this I am not able to write my data into one of the TX characteristics to transmit data to the mobile.
This results in sd_ble_gatts_hvx() returning error code as 8 - INVALID STATE.
As a workaround I added the following:
    case BLE_GAP_EVT_CONNECTED:
    	gu16_connhandle = lsp_ble_evt->evt.gap_evt.conn_handle;
    	errcode = sd_ble_gatts_sys_attr_set(gu16_connhandle, NULL, 0, 0);
As this did not work, I tried doing the following too:
    	lu16ar_Buffer[0] = 16;      // cccd handle
    	lu16ar_Buffer[1] = 2;       // cccd attribute size = 2
    	lu16ar_Buffer[2] = 1;       // 1 = enable notifications
    	lu16ar_Buffer[3] = 0xCACD;  // CRC-CCITT (0xFFFF)
    	lu32_errcode = sd_ble_gatts_sys_attr_set(gu16_connhandle, (u8*)lu16ar_Buffer, 8, 0);
Inspite of doing the above, I did not have any luck transmitting the BLE data that I intend to.
Is there any way that I can transmit (write in the characteristics) without the notification being enabled from the Android APP?
I am using SDK 12.1
Thanks in advance!
