nRF52832: Power OFF/Reset with UART connected
I wanted to know if the UART pins can cause any issues if kept connected to usb (Rx/Tx pins stable to 3.3V) and directly to the GPIOs of the nRF52, while performing a soft-reset or switching OFF and then ON the device.
I have a sensor (ADXL362) connected to nRF52 via SPI and when I restart the device, all internal registers of this sensor appear to be reset to 0x00 (which should not be possible, they should have some defaults values). Thus this makes me suspect that SPI is not actually succeeding in reading those registers, but no error is shown. When, in addition to switching off the device, I also disconnect the UART connector, then the system gets reset properly and registers of the sensor are read correctly.
Can anyone help me understand what is happening?
Thank you in advance. Marco
  • Another question, by default at reset GPIO pins are configured to be INPUT with NOPULL and DISCONNECT INPUT BUFFER. What does actually "disconnect input buffer" mean? Wouldn't it be safer to have the GPIO pins configured as output or input with pull-up by default?
  • You will probably not damage the chip, but as you are out of spec we cannot promise anything.
    Input buffer is, well the input buffer, used to read the state of the pin. If the input buffer is disconnected you cannot read the state of the pin from the IN register. This has nothing to do with the protection diodes, those are on all the gpio pins regardless of their configuration. The gpio is configured as input with input buffer disconnected which means that they do nothing (don't have any function). Configure them as output by default might give unwanted behavior (like shorts). Pull up is normally not used, so this should be off, it might also lead to leakage current (pin is low, pull up resistor is on).
