PA LNA in a serialized application
I am currently working with two nrf52 boards in a serialized configuration. I wanted to add the PA and LNA pin toogle on the connectivity chip. As the gpio can't be configured from the application chip, I did a little work around to allow the application to ask the connectivity to enable PA and LNA pins : I added the following code in the connectity application (in conn_mw_ble.c, in the function conn_mw_ble_opt_set()):
if(opt_id == BLE_COMMON_OPT_PA_LNA){
    sd_err_code = pa_lna_init(19,20);
}else{
    sd_err_code = sd_ble_opt_set(opt_id, p_opt);
With pa_lna_init(), the function you gave in an other forum post.
And I used it as follow on the application chip :
gap_params_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
// Start execution.
NRF_LOG_INFO("Heart Rate Sensor Start!\r\n");
sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, NULL);
This configuration works perfectly with the SPI 5W serialization, but stop after the call to sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt) in the standart SPI serialization (6 wires).
Does anybody have an idea of the differences between the normal SPI and the 5W SPI which could lead to this behavior ?
Romain
