I use the SPI slave function on 51422. When I send a byte(0x31) to 51422 SPI slave from master, 51422 will back a byte (0xAA - DEF byte) to master. Why?
I send 0x31 every 1 seconds, but I always get 0xAA. Why??
P.S. I figured out that SPI1_TWI1_IRQHandler is never being called for the second time, and all the NRF_SPIS1 registers are in the same state before and after the transaction (checked it in the main slave example loop).
Are you setting the buffers after the completed transaction? By calling "spi_slave_buffers_set" after a finished transaction, you will acquire the semaphore again and ready the SPIS for a new transaction.
The problem is solved - I misconfigured my master so that slave select didn't work the proper way
