Can I stop interrupts for 2ms in an orderly manner without crashing the S110?
It should be ready in about a month or so. If you need something sooner you can try the good tip from Alex, and use the radio notification feature.
Typically the SPI master can live with interrupts, as the master is in control of the data transfer. Will your slave time out if the delay between bytes is too large?
We have many different plans for the future, unfortunately I can't reveal specifics yet...
Thank you Alex, thats a great workaround. And thank you Torbjørn for the information.
I am testing Alex tip and it seems like a good workaround while you get the new SoftDevice out. If there is a way to test the beta of that version I am in :).
Thanks again for the workaround and the later solution.
Antonio.
Hello everyone.
I'm very new to nRF51 and S110, but I was facing to the same problem for a couple of days. Do we have some progress in this topic? Does any new version of S110 have workaround to this?
FYI, the reason I needed a time critical control is a UART peer device requires odd-parity even though nRF51 supports only even-parity so I needed bit-banging.
Best Regards,
Atsushi
