hello there,
i am giving external supply to nrf51. my external supply is usb 3.3 v. but when i connect it with nordic and then if i check it on multimeter , it shows me 2.12 v. can you tell me why??
hello there,
supply voltage of LM1117 is 5 v. output is 3 v
Are you using the same schematics as shown in the datasheet here (page 1)?
LM117T is a 3.3V regulator.
If you are getting 3.0v offload, you already have a problem before you attach the nRF51.
i am getting 3.3 v. but i am using variable resistor to voltage
According to the datasheet(page 6) the adjustable version of the LM1117 needs a minimum load current of 1.7mA to maintain regulation. The nRF51 will typically not use this much current, and the adjustable version of LM1117 is therefore not suited for low-power applications.
