Trying to locate an IC programmer manufacturer that supports ALL of these devices.
1- nRF 51422QFAC 2- nRF 52832QFAA 3- nRF 51822QFAA
Thank you
Thank you
For production programming we have a infocenter page here you should take a look at. We also have a more detailed whitepaper here.
Summarized:
You have two options when programming for production:
In-system programming (ISP): ISP is used when programming is needed after the assembly of the final PCB. Here we recommend using a SEGGER Production Programmer.
Socket programming: Socket programming is used when the SoC is pre-programmed before it's mounted on a PCB. Here we recommend using a production programmer from either Elnec or Hi-Lo systems.
The IDAP-Link can used. It can flash softdevice + App + DFU all at once. It can also parallel program with multi-boards.
