Slow Wake-Up and Timer Start from Power Off
I am trying to set the nRF52 to power off and wake up on a momentary button push (scope measures momentary push logic low around 50ms-100ms). However, I am struggling to have my debounce timer start up fast enough to detect the button being still pressed. If I hold the button down for a longer press, 200ms+, then I am able to read the button pin as registering a press in my debounce timer. The nRF52 tOFF2ON is stated as 16.5us, so I am thinking the timer is not starting fast enough or the button pin is not setup quick enough? Any direction would be very helpful!
First I set up my button input and debounce timer:
int
main (void)
  uint32_t err_code;
  uint32_t time_ticks;
  uint32_t time_ms = 1; //Time(in miliseconds) between consecutive compare
  //Initialize.
  err_code = NRF_LOG_INIT(NULL);
  /*********** Manual Input Config ******************/
  err_code = nrf_drv_gpiote_init ();
  //nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(false);
  in_config.pull = NRF_GPIO_PIN_PULLUP;
  err_code = nrf_drv_gpiote_in_init (BUTTON_1, &in_config, in_pin_handler);
  nrf_drv_gpiote_in_event_enable (BUTTON_1, true);
  // Check initial button state
  if (button1_is_pressed())
      btnpressed = 1;
  /*********** Timer Config ******************/
  err_code = nrf_drv_timer_init (&TIMER_LED, &timer_cfg,
				 timer_callback_handler);
  time_ticks = nrf_drv_timer_ms_to_ticks (&TIMER_LED, time_ms);
  nrf_drv_timer_extended_compare (&TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks,
				  NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
  nrf_drv_timer_enable (&TIMER_LED);
Here is my code to setup power off:
void
sleep_mode_enter (void)
  //uint32_t err_code;
  nrf_drv_gpiote_out_set (LED_1);
  //err_code = bsp_wakeup_button_enable(0);
  //err_code = nrf_gpio_cfg_sense_set( BUTTON_1, BUTTONS_ACTIVE_STATE ? NRF_GPIO_PIN_SENSE_HIGH :NRF_GPIO_PIN_SENSE_LOW );
  nrf_gpio_cfg_sense_set ( BUTTON_1, NRF_GPIO_PIN_SENSE_LOW);
  nrf_drv_timer_compare_int_disable(&TIMER_LED,NRF_TIMER_CC_CHANNEL0);
  nrf_drv_timer_disable (&TIMER_LED);
  sd_power_system_off ();
//  err_code = sd_power_system_off ();
//  APP_ERROR_CHECK(err_code);
  while (1)
Here is my button debounce timer handler, after a short momentary push from wake-up, the system is seeing "state" as false, if I hold the button down for a long press it measures true.
void timer_callback_handler (nrf_timer_event_t event_type, void* p_context)
  static uint32_t button_debounce = 0;
  bool state;
  switch (event_type)
    case NRF_TIMER_EVENT_COMPARE0:
      total_ticks++;
      state = button1_is_pressed();
      if (state && btnpressed) // Still held down
