Transmit and Receive data via UART
I have compiled and debugged the temperature_pca10036 code from nRF5_SDK_v11.0. I have used termite terminal for getting info about transferring of data from nRF52832 board to PC. And i haven't got the output for the code. Is this, the way correct. Please help with simple code for analysing the data transfer in UART.
  • Thankyou sir for your kind approach. I have made the code correctly as per your guide and its working in good.
  • Hi Sadasivam,
    I am facing same problem. I am using nRF52832 pca10040. IDE using is eclipse.
    I want to transmit 0-9 numbers using UART. The transmitted data equals to received data the LED should blink otherwise it should be off state.
    I am begineer, that is why facing small problem. Please help me with the code.
    Thank you in advance.
    Here is the code that I developed take a look suggest changes.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #define MAX_TEST_DATA_BYTES     (15U)
    #define UART_TX_BUF_SIZE 256
    #define UART_RX_BUF_SIZE 256
    //  UART error handler function.
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    // LED glow function: When data Transmitted is equal to data Received then LED glow up else stays off.
    void led_blink()
        bsp_board_leds_init();
        while (true)
            for (int i = 0; i < 1; i++)
                bsp_board_led_invert(i);
                nrf_delay_ms(500);
    //   UART transmit function.
     #if ((Enable_UART_TxDecimalNumber==1) || (Enable_UART_TxFloatNumber==1))
    void UART_Tx(uint32_t dec_no, uint8_t nod)
    		uint8_t i=0;
    		printf("\nEnter decimal no to transmit:");
    		scanf("\n%d", &dec_no);
    		if(dec_no==0)																			//decimal number to transmit
    			for(i=0; ((i<nod) && (i<max_dttx)); i++)											//number of digits to transmit
    			a[i] = 0x00;																		//maximum number of digits to transmit
    		else if
    			for(i=0; i<nod; i++)
    				if(dec_no!=0)
    					a[i] = util_GetMod32(dec_no,10);
    					dec_no = dec_no/10;
    		else if( (nod == dttx) || (nod > max_dttx))												//total numbers to transmit
    				a[i]=0;
    	while(i)
    		UART_TxChar(util_Dec2Ascii(a[i-1]));													//Convert decimal to ASCII
    		i--;
    	void led_blink();
    //  main Function.
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              APP_UART_FLOW_CONTROL_ENABLED,
              false,
              UART_BAUDRATE_BAUDRATE_Baud19200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
        UART_Tx();
    	return 0;
  • I see you posted you question in this thread. Please continue discussion in that thread.
