nRF51: IoT-MQTT Publisher Example problems
Hi, I just read IoT-MQTT example and have almost exactly the same problem but with the Publisher. I am running a PI with Raspberian 4.4.34-v7+. I have installed mosquitto on the PI and have radvd installed. I turned on the IPV6 forwarding (echo 1 > /proc/sys/net/ipv6/conf/all/forwarding), did the config file and restarted radvd. This worked ONCE. I did get this:
sudo echo 1 > /proc/sys/net/ipv6/conf/all/forwarding
root@raspberrypi:/home/pi# sudo service radvd restart
root@raspberrypi:/home/pi# ifconfig bt0
bt0       Link encap:UNSPEC  HWaddr B8-27-EB-FF-FE-F1-72-D4-00-00-00-00-00-00-00-00
inet6 addr: 2001:db8::ba27:ebff:fef1:72d4/64 Scope:Global
inet6 addr: fe80::ba27:ebff:fef1:72d4/64 Scope:Link
UP POINTOPOINT RUNNING MULTICAST  MTU:1280  Metric:1
RX packets:47 errors:0 dropped:0 overruns:0 frame:0
TX packets:52 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:1906 (1.8 KiB)  TX bytes:2808 (2.7 KiB)
This is with the Publisher connected to bt0. The publisher has the 2001:... address compiled in. I then run mosquitto -v on the PI but when I press button 1 all 4 LED's light up and stay lit showing it failed. I get no messages on mosquitto.
But now if I disconnect and re-connect bt0 does NOT have the global address anymore. I even re-booted the PI and did the whole sequence all over again starting with loading 6lowPAN and still it does not get the global address. Do you have any suggestions of what to try next.
And one more question. The disconnect does not work. When I try to do:
echo "disconnect 00:EF:0B:A4:88:A6" > /sys/kernel/debug/bluetooth/6lowpan_control
I get a write error of invalid argument. That is the correct MAC.
Thank you for the help. --jim schimpf
  • Yes, I have been seeing that issue as well(same setup with an unsecured connection), the solution in my case was to repeatedly try to make a connection with the MQTT broker untill it returns NRF_SUCCESS. I also think that I spottet a mistake in my bash script, there should be a
    sudo ifconfig btX add 2001:db8::1/64
    after for loop that connects to the devices.
  • I am using different IPV6 addresses (FD00:a::xx for the Nordic) FD00:b::1 for the PI and FD00:b::2 for the PC. but I have the line ifconfig bt0 add fd00:a::/64 and ifconfig eth0 add fd00:b::1/64 in my setup script. The problem is as soon as I try to make the connection I get the error deep in the Softdevice (file rem.c line 610) and it goes to the app_error_handler and into an infinite loop in that routine. This file doesn't seem to be in my IOT sources.
  • These addresses are all based on this Article which I went through to get IPV6 working.
  • Hmm, I do not know if using a different prefix than the one we provide in the IoT SDK would cause this issue. Could you try to use the setup described in the doc, i.e. use the 2001:db8::1/64 prefix? I have not seen that the SoftDevice asserts upon connection to the mosquitto broker( rem.c is one of the internal source files of the SoftDevice). Are you stepping through the code when attempting to connect?
  • Further work and I have found the 0C942 error code. This occurs in the button press for connect routine. It gets an error_code from mqtt_connect() and then calls APP_ERROR_CHECK(). The error code returned is 51522 = 0xC942. And APP_ERROR_CHECK() is a fron tend for app_error_handler() which sets all the LEDs ON and then enters a endless loop. And that effectively ends the program. So the connect is failing. Found the problem by tracing down into the code. It is failing on the tcp_connect() and fails because NO ROUTE TO HOST . I guess I need a route for the FD00:a:: to FD00:b::2 In the PI
