Hi, can you help me out please: I have followed devzone.nordicsemi.com/.../ and have configured as it shows.
But NRF_LOG_INFO does not work however SEGGER_RTT_printf does.
What should i do?
Thanks
What should i do?
Thanks
Are you sure that the config actually got set? CMSIS config wizard seems to require you to switch to view another config before saving for the value to be updated. I would recommend that you open the sdk_config.h file in a text editor and make sure the config is set there.
I agree that sometimes this can happen but I have confirmed settings are OK for what I understand is required:
NRF_LOG_ENABLED 1
NRF_LOG_BACKEND_RTT_ENABLED 1
NRF_LOG_DEFERRED 0
NRF_LOG_BACKEND_UART_ENABLED 0
I have tried other sample projects and none of them seem to work OOTB either although I did manage to get one working which is what I have been using as my base - wish I could remember what I did...
You are able to debug the application in SES? Which version of SES and J-Link are you using? I'm not sure what can cause issues if you are not able to see the logs with a clean SDK. As I said, I tested this and it worked well.
Hi did you got the solution for your problem ? because I am facing the same issue and I also toke same debug steps like you !
Please check if this solves your issue.
